Hi, I'm having the stock radiator re done in my car and when I took it out, I noticed that the driver side hard line coming out of the automatic trans cooler has a kink causing a slight restriction.  If anyone has the brass fitting and the 90 degree hard line still in good shape from an automatic trans I'm in need.  I'm in Central Ca near Modesto.  Please call or text me at (209) 405-4465.  Thanks!!!
