Posted August 2, 20168 yr comment_500109 does anyone have a close-up picture of the rear hatch weatherstripping? i want to make sure i put it on correctly thanks all sb Link to comment https://www.classiczcars.com/forums/topic/55894-rear-hatch-weatherstrip/ Share on other sites More sharing options...
August 2, 20168 yr comment_500120 i bought one from vintagerubber.com and the shop cannot seem to find a way to install it! I guess they are just plain dumb!! I dont think vintage rubber sent me a wrong rear hatch weatherstrip for my 1972 240z Edited August 2, 20168 yr by jalexquijano Link to comment https://www.classiczcars.com/forums/topic/55894-rear-hatch-weatherstrip/#findComment-500120 Share on other sites More sharing options...
August 2, 20168 yr comment_500129 Here is how I did mine. For the 3 piece strip, I put the center one in first, centering as best I could. Then put on the two sides....trimmed the extra length. Hope the pics are clear enough Link to comment https://www.classiczcars.com/forums/topic/55894-rear-hatch-weatherstrip/#findComment-500129 Share on other sites More sharing options...
August 2, 20168 yr Author comment_500131 9 minutes ago, motorman7 said: Here is how I did mine. For the 3 piece strip, I put the center one in first, centering as best I could. Then put on the two sides....trimmed the extra length. Hope the pics are clear enough perfect! thank you Link to comment https://www.classiczcars.com/forums/topic/55894-rear-hatch-weatherstrip/#findComment-500131 Share on other sites More sharing options...
August 3, 20168 yr comment_500159 Just to let you know the shop finally managed to install it! Thanks for the pictures! Link to comment https://www.classiczcars.com/forums/topic/55894-rear-hatch-weatherstrip/#findComment-500159 Share on other sites More sharing options...
September 1, 20168 yr comment_502246 On 8/3/2016 at 11:34 AM, jalexquijano said: Just to let you know the shop finally managed to install it! Thanks for the pictures! I'm curious to know how the shop did it? There is no welting so I am guessing you have to use weatherstrip glue and tape to hold it in place? Link to comment https://www.classiczcars.com/forums/topic/55894-rear-hatch-weatherstrip/#findComment-502246 Share on other sites More sharing options...
September 1, 20168 yr Author comment_502254 1 hour ago, hatepotholez said: I'm curious to know how the shop did it? There is no welting so I am guessing you have to use weatherstrip glue and tape to hold it in place? yes. i used 3M weatherstrip glue. just follow the directions and take your time Link to comment https://www.classiczcars.com/forums/topic/55894-rear-hatch-weatherstrip/#findComment-502254 Share on other sites More sharing options...
September 1, 20168 yr comment_502258 35 minutes ago, sweatybetty said: yes. i used 3M weatherstrip glue. just follow the directions and take your time Thanks! Link to comment https://www.classiczcars.com/forums/topic/55894-rear-hatch-weatherstrip/#findComment-502258 Share on other sites More sharing options...
September 1, 20168 yr comment_502259 I used a lot of spring loaded clamps to ho;d my Vintage rubber weatherstrip in place while the glue dried. Link to comment https://www.classiczcars.com/forums/topic/55894-rear-hatch-weatherstrip/#findComment-502259 Share on other sites More sharing options...
September 3, 20168 yr comment_502397 On 8/31/2016 at 11:22 PM, Mikes Z car said: I used a lot of spring loaded clamps to ho;d my Vintage rubber weatherstrip in place while the glue dried. good idea, Thanks! Link to comment https://www.classiczcars.com/forums/topic/55894-rear-hatch-weatherstrip/#findComment-502397 Share on other sites More sharing options...
