Recently Browsing 0
Who's Online (See full list)
Continuing the tear down on my project. I have been slowly removing components to evaluate and refurbish as the project slowly moves forward. The engine is still in the car-less storage space needed. I have been struggling with the manifolds. i have been spraying the hardware with Blaster everytime the hood has been popped for the past several weeks. The rear exhaust stud is missing and I snapped off the front one with barely any force. The center bolt did come out OK. The factory service manual simply states remove the EGR valve, etc. The valve has been successfully removed with the Blaster and a bit of heat but the connecting tubes are a different story. Any tips or suggestions will be appreciated, even an elimination of the EGR system if that would not cause performance or driveability issues with the engine after we get it rebuilt and running. Thanks for the help in advance. John-Lugoff, SC
https://www.classiczcars.com/forums/topic/55909-egr-and-manifold-removal-tips-78-280z/Share on other sites
