280z Wiring Diagram
Mike
Originally posted by 2ManyZs
I could try to scan one out of an old Haynes manual, but what year do you/they need?
How many different versions are available? I'd like to get them all on this site if possible. Right now we have 240z and 260z.
Kieth, set your DPI resolution to 600 or so. Email it to me and I can modify it to work here.
IE: Scan at the highest resolution (600+ dpi) and use black/white mode. You can try greyscale or even full color photo to see what they turn out like.
The 78 280Z has two different wiring harnesses. I found out through trial and error. The post 5/78 builds use a harness that is similar to a 79 280ZX, 2 fuel pump relays and a separate fuel injection relay.
I have this schematic, not in electronic format, but could send it.
I was informed by a Datsun Technician, that the others, 75 - 78 are almost the same, for all practical purposes. I have a factory 75 schematic as well.
Ed Palmer
