February 18, 20178 yr comment_513202 I bought this used splash pan a few weeks ago. It obviously needs to be cleaned up and painted. It would take some work to fabricate a pan with similar dimensions, but no one is making new pans that I'm aware of. Robert S. Link to comment https://www.classiczcars.com/forums/topic/55999-replacement-inner-rocker-panels/?&page=6#findComment-513202 Share on other sites More sharing options...
February 18, 20178 yr comment_513212 That would be a hot seller Link to comment https://www.classiczcars.com/forums/topic/55999-replacement-inner-rocker-panels/?&page=6#findComment-513212 Share on other sites More sharing options...
February 18, 20178 yr comment_513217 That would be a hot sellerYeah I've been looking for one. Don't really like the idea of roadkill getting blood on my oil pan. Link to comment https://www.classiczcars.com/forums/topic/55999-replacement-inner-rocker-panels/?&page=6#findComment-513217 Share on other sites More sharing options...
February 18, 20178 yr comment_513220 I would love a modern version punched out of stainless... Link to comment https://www.classiczcars.com/forums/topic/55999-replacement-inner-rocker-panels/?&page=6#findComment-513220 Share on other sites More sharing options...
February 18, 20178 yr comment_513246 @disepyonBuild an undershroud that can be flat shipped, either riveted or bolted together that has a modern functional look and you will sell lots. Guys going for the OEM look will want an original piece anyways. Make it a custom unit, maybe out of stainless or powder coated and it will be a hit! Link to comment https://www.classiczcars.com/forums/topic/55999-replacement-inner-rocker-panels/?&page=6#findComment-513246 Share on other sites More sharing options...
February 18, 20178 yr comment_513248 Also, keep in mind the splash pan for the '70 - '74 is different from the pan for the 74 1/2 - '78. I think you can still get the later splash pans from Nissan and the mounting holes are located slightly off from the early versions.Robert S. Sent from my HTC6545LVW using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/55999-replacement-inner-rocker-panels/?&page=6#findComment-513248 Share on other sites More sharing options...
February 18, 20178 yr comment_513272 @EhlersRS If I may, what did a used splash pan run you? For Iowa the condition isn't too bad. A little rusty on the inside near the back but no obvious really rotten areas Link to comment https://www.classiczcars.com/forums/topic/55999-replacement-inner-rocker-panels/?&page=6#findComment-513272 Share on other sites More sharing options...
February 19, 20178 yr comment_513284 [mention=20033]EhlersRS[/mention] If I may, what did a used splash pan run you? For Iowa the condition isn't too bad. A little rusty on the inside near the back but no obvious really rotten areasHey Patcon, This pan came from a guy in NC and I think it was originally on a '73 model. I paid $100 for the pan and $30 for shipping. From what I've seen a pan in average to good condition will run around $200. After the pan arrived here, I noticed there is some pitting on the area you mentioned. I'll decide if it needs repair after blasting the rust off, otherwise I'll just repaint it.Robert S. Link to comment https://www.classiczcars.com/forums/topic/55999-replacement-inner-rocker-panels/?&page=6#findComment-513284 Share on other sites More sharing options...
February 19, 20178 yr comment_513293 Thanks, Those numbers are similar to what I have seen too, and many of those are pretty well beat up. Yours looks pretty straight all things considered. You could also use a rust remover from Eastwood which will not remove any good metal, since the panel isn't really very thick anyway... Link to comment https://www.classiczcars.com/forums/topic/55999-replacement-inner-rocker-panels/?&page=6#findComment-513293 Share on other sites More sharing options...
February 19, 20178 yr comment_513295 Thanks, Those numbers are similar to what I have seen too, and many of those are pretty well beat up. Yours looks pretty straight all things considered. You could also use a rust remover from Eastwood which will not remove any good metal, since the panel isn't really very thick anyway...Thanks for the advice on the Eastwood product. These pans are definitely made from a thin gauge panel! Robert S. Sent from my HTC6545LVW using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/55999-replacement-inner-rocker-panels/?&page=6#findComment-513295 Share on other sites More sharing options...
February 19, 20178 yr Author comment_513321 Interesting Ideas. Will keep a list of your suggestions and hopefully to show up on my site someday soon. Keep them coming. Managed to get the seat brackets finished. However as of yet these have not been approved yet for fitment. Once approved they are ready for purchase (https://www.prospect-d.com/). Can also review the installation guide as well in the install guide section. Similar to the ones I made for my Z, already posted pictures. These appear to fit and made a lot better. Pictures: Link to comment https://www.classiczcars.com/forums/topic/55999-replacement-inner-rocker-panels/?&page=6#findComment-513321 Share on other sites More sharing options...
February 19, 20178 yr comment_513370 Definitely think you will have a market for these. Very nice workSent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/55999-replacement-inner-rocker-panels/?&page=6#findComment-513370 Share on other sites More sharing options...
