Posted August 19, 20168 yr comment_501413 Oh so wise Z community! I need your assistance desperately! I have a short... Somewhere! I currently have, running lights at all. I also have no dash lights, marker lights, tail lights, or engine light. I believe the dome light is also not working. What I do have is headlights, turn signals, brake lights, map light, and radio. When I change the fuse (tried 3 times) it immediately flashes and burns.. So much so that I burned my finger. Oh wise ones! You direction and help is very needed! Thanks much! Kira The lil z lady Edited August 19, 20168 yr by KiraK Link to comment https://www.classiczcars.com/forums/topic/56006-help-have-a-short-somewhere-72-240z/ Share on other sites More sharing options...
August 19, 20168 yr comment_501429 Do your gauges work? I lost those and a bunch of lights and it was popping the IGN fuse as soon as I turned the key. The car was running but I had a bad alternator that was "back feeding current through the ignition"? Another problem I had some years ago was no dash lights, my combo switch had gone bad. The way they are made every time you turn on the lights it archs on the plates internally. I fixed it myself, it was a bitch but I have more time than money. This is what I went by, http://www.kamikazeracing.org/dl/ZTech/Rebuild_240Z_combo_switch.pdf And here's a picture that shows the contact points. You might could talk to Mr Irwin about rebuilding yours. Click on "services", http://datsun-240z-upgrades.net/ Good luck! Link to comment https://www.classiczcars.com/forums/topic/56006-help-have-a-short-somewhere-72-240z/#findComment-501429 Share on other sites More sharing options...
August 19, 20168 yr comment_501431 What fuse are you replacing? You may just have a corroded light socket somewhere. The side markers are bad about holding water behind the lense and rusting out the socket. Link to comment https://www.classiczcars.com/forums/topic/56006-help-have-a-short-somewhere-72-240z/#findComment-501431 Share on other sites More sharing options...
August 19, 20168 yr comment_501441 It starts with corrosion in the sockets. It ends with a meltdown of the fusebox. Been there. Done that. Got the T-shirt. I have seen the fuse fail with such a tiny break that I to magnify the image of the fuse to find it. When I replaced the fuse, the new one stayed intact long enough to heat up the fuse box to the point of melting down. First always put the year of your car in your posts. The electrical systems did change over the years. I can give better diagnostics with that info. Link to comment https://www.classiczcars.com/forums/topic/56006-help-have-a-short-somewhere-72-240z/#findComment-501441 Share on other sites More sharing options...
August 19, 20168 yr comment_501442 I think she has a '72 #110 with white interior, just like mine. Link to comment https://www.classiczcars.com/forums/topic/56006-help-have-a-short-somewhere-72-240z/#findComment-501442 Share on other sites More sharing options...
August 19, 20168 yr comment_501453 You want to check the fuse at the red box. If you don't take care of the problem, the fuse box cover could end up looking like the one in the second photo. Link to comment https://www.classiczcars.com/forums/topic/56006-help-have-a-short-somewhere-72-240z/#findComment-501453 Share on other sites More sharing options...
