Posted August 29, 20168 yr comment_502097 is there only one seal on the tail lights, the tail light to body? when i put the finisher trim on there is a gap between it and the tail light and you can see in there. it looks like there may be something missing. or, was the the housing just painted black? mine is a lite grey color that you see in the pic below even with the trim on. thanks all sb Edited August 29, 20168 yr by sweatybetty Link to comment https://www.classiczcars.com/forums/topic/56076-another-tail-light-question-1972/ Share on other sites More sharing options...
August 30, 20168 yr comment_502133 You are doing everything correctly. Just install the tail light surrounds and center piece. Looks good! Chuck Link to comment https://www.classiczcars.com/forums/topic/56076-another-tail-light-question-1972/#findComment-502133 Share on other sites More sharing options...
September 29, 20168 yr Vendor comment_504063 There was a very thin trim ring in between the panels and the light assemblies originally. The OE part numbers were 79902-E4100 and 79903-E4100 but they are no longer available. You can always fabricate something if it really bothers you but that's how it came from the factory. Link to comment https://www.classiczcars.com/forums/topic/56076-another-tail-light-question-1972/#findComment-504063 Share on other sites More sharing options...
September 30, 20168 yr Author comment_504072 i did end up painting the housings with some krylon fusion paint. looks much better now, but time will tell Link to comment https://www.classiczcars.com/forums/topic/56076-another-tail-light-question-1972/#findComment-504072 Share on other sites More sharing options...
