September 11, 20168 yr comment_502925 Yeah, I did a little digging before I got bored with the research. DIN 73379 seems to be a "family", and it all comes down to the "Type". I got tired of digging into it before I got to the bottom of exactly what "Type B" was. Some of the types are clearly suitable, but not sure about "B", The working pressure is certainly suitable, but I'm not sure about the permeability or longevity at temp. "Proof is left to the student"? Can I pull that? Link to comment https://www.classiczcars.com/forums/topic/56153-can-this-fuel-line-be-used-as-part-of-the-efi-unit/?&page=2#findComment-502925 Share on other sites More sharing options...
September 11, 20168 yr Author comment_502927 Here is what I found... Because of location, the hose should be of Type A as that is fire resistant. Type B is meant to be used to connect to the tank, as an example. The search goes on... Link to comment https://www.classiczcars.com/forums/topic/56153-can-this-fuel-line-be-used-as-part-of-the-efi-unit/?&page=2#findComment-502927 Share on other sites More sharing options...
