September 16, 20168 yr comment_503356 What about a new head bolt set? Nissan turbo set if you can find them. Link to comment https://www.classiczcars.com/forums/topic/56173-l28-rebuild-needs-advice/?&page=3#findComment-503356 Share on other sites More sharing options...
September 16, 20168 yr comment_503377 I used Arp head bolts. Link to comment https://www.classiczcars.com/forums/topic/56173-l28-rebuild-needs-advice/?&page=3#findComment-503377 Share on other sites More sharing options...
September 17, 20168 yr comment_503388 here's some Nissan part numbers that are still good and available. Oil pan gasket, 11121-E3001. $15 Rear main crank seal, 12279-2B500. $30 Rear main crank side seals, 12289-W0400. 2 at $2 each, $4. Turbo head bolts, short ones you need 9, 11056-P7600. $4 each Turbo head bolts, long ones you need 5, 11059-P7600. $5 each Those prices are in between list and what I have to pay, I get a discount. The turbo oil pump from Advance is cast iron which will add a couple of pounds over the original aluminium but after the discount it's only about $60. It's a Melling P/N 152. You'll read a lot about the turbo pump is P/N 111 but I emailed their tech department and was told the pumps are the same except the turbo automatic transmission pump has a higher bypass pressure so that makes it flow more before bypassing back into the pan. So the #152 is what he suggested that I buy. FYI only! I'm a shade tree mechanic with access to the world wide web, almost dangerous. Link to comment https://www.classiczcars.com/forums/topic/56173-l28-rebuild-needs-advice/?&page=3#findComment-503388 Share on other sites More sharing options...
September 17, 20168 yr Author comment_503402 8 hours ago, S30Driver said: What about a new head bolt set? Nissan turbo set if you can find them. The engine Gasket kit from Datsun sprint included head bolts. Link to comment https://www.classiczcars.com/forums/topic/56173-l28-rebuild-needs-advice/?&page=3#findComment-503402 Share on other sites More sharing options...
September 17, 20168 yr Author comment_503443 22 hours ago, siteunseen said: here's some Nissan part numbers that are still good and available. Oil pan gasket, 11121-E3001. $15 Rear main crank seal, 12279-2B500. $30 Rear main crank side seals, 12289-W0400. 2 at $2 each, $4. Turbo head bolts, short ones you need 9, 11056-P7600. $4 each Turbo head bolts, long ones you need 5, 11059-P7600. $5 each Those prices are in between list and what I have to pay, I get a discount. The turbo oil pump from Advance is cast iron which will add a couple of pounds over the original aluminium but after the discount it's only about $60. It's a Melling P/N 152. You'll read a lot about the turbo pump is P/N 111 but I emailed their tech department and was told the pumps are the same except the turbo automatic transmission pump has a higher bypass pressure so that makes it flow more before bypassing back into the pan. So the #152 is what he suggested that I buy. FYI only! I'm a shade tree mechanic with access to the world wide web, almost dangerous. Thanks. This post really helps me a lot. Link to comment https://www.classiczcars.com/forums/topic/56173-l28-rebuild-needs-advice/?&page=3#findComment-503443 Share on other sites More sharing options...
September 17, 20168 yr Author comment_503444 I just took the Camshaft out and planning on sending them to Delta Cam for a regrind. I asked the guy and he told me a .488 lift and 230 Duration@0.050" spec fits for my street proformance build. I will need some new lash pads indeed, But I'm worried about this much lift is good for piston clearence or not. Anybody has got their camshaft regrinded by Delta? What's your suggestion on the lift or duration? Link to comment https://www.classiczcars.com/forums/topic/56173-l28-rebuild-needs-advice/?&page=3#findComment-503444 Share on other sites More sharing options...
September 18, 20168 yr comment_503446 Factory specs are 248 and .413". 230 and .488" are odd numbers. Lower duration, with a mild increase in lift. Something's not right there. MSA's weakest performance cam has bigger numbers, and many say that Stage 1 isn't worth the work. Most people say to go bigger than you'd think, the Z engines like it. http://www.thezstore.com/page/TZS/PROD/10-2001 Browse through the specs. and descriptions of their selection - type "performance camshaft stage" in to their search box. Their cookies function won't allow a page of search items to be copied over. Their loss. Edited September 18, 20168 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/56173-l28-rebuild-needs-advice/?&page=3#findComment-503446 Share on other sites More sharing options...
September 18, 20168 yr comment_503455 I have the stage 3 from msa and thats a great all around performing cam. Good idle and low end power and makes power up to 6500-7000 rpms. Link to comment https://www.classiczcars.com/forums/topic/56173-l28-rebuild-needs-advice/?&page=3#findComment-503455 Share on other sites More sharing options...
September 18, 20168 yr Author comment_503472 Going for MSA stage 3! Is that good for twin SUs? Otherwise I can change after the cam arrived at Delta. Link to comment https://www.classiczcars.com/forums/topic/56173-l28-rebuild-needs-advice/?&page=3#findComment-503472 Share on other sites More sharing options...
September 18, 20168 yr comment_503477 I run tripples but i guess it will work fine with SUs. Its not a "big" cam. Link to comment https://www.classiczcars.com/forums/topic/56173-l28-rebuild-needs-advice/?&page=3#findComment-503477 Share on other sites More sharing options...
September 19, 20168 yr Author comment_503519 18 hours ago, moelk said: I run tripples but i guess it will work fine with SUs. Its not a "big" cam. Thanks. MSA didn't say it fits for SUs but I guess I'll try that. Link to comment https://www.classiczcars.com/forums/topic/56173-l28-rebuild-needs-advice/?&page=3#findComment-503519 Share on other sites More sharing options...
September 19, 20168 yr comment_503523 Here's a couple of good reads for shorter valve seals. http://forums.hybridz.org/topic/25807-improved-l6-valve-stem-seals/ http://forums.hybridz.org/topic/68120-problem-with-viton-valve-seals/ I've read anything over .460 needs stiffer springs and the shorter valve seals. I put the Felpro SS72686 on my stock E88 as a practice run for myself. They're a little tricky getting them down without going too far. I used a deep well socket that rest on the metal part of the seals and drove them down with a rubber hammer. If you take your time there are easy, after the first one. Link to comment https://www.classiczcars.com/forums/topic/56173-l28-rebuild-needs-advice/?&page=3#findComment-503523 Share on other sites More sharing options...
