Posted September 14, 20168 yr comment_503166 well that was easy. My headliner was detached for about 1/3 of the way on the driver side, sagging down and rubbing my head (I am tall so any sag at all is an issue). Got some headliner 3M glue, used a spatula to separate the driver and passenger side and then about 1/2 back (the rest was stuck on very well, I did not want to tear up the foam) where it was not holding real well. Covered the interior with bed sheets (seats/dash, anywhere it looked like overspray could be and issue) reclined the seats, put the brake handle down all to get as much unfettered access as possible, sprayed on a good even coat on both the roof and headliner, let it tack up (did not take long the heat the metal was not hot as it was in the garage, but the air temp was about 90f) then started from the middle worked up and over both sides. when I got to the edges (no glue about the last 4") I used the plastic spatula to tuck in. This has to be one of the easiest projects on the Z so far. Not completely detaching it no doubt made the alignment easy. Edited September 14, 20168 yr by Dave WM Link to comment https://www.classiczcars.com/forums/topic/56179-headliner-done/ Share on other sites More sharing options...
