maton_acoustic Posted September 17, 2016 Share #1 Posted September 17, 2016 Hi, my Datsun 260z has a really loud violent rear end knock. It only happens when I get the rpm quite high (above 3000) and then let off the throttle. It sounds like it's in the diff area but I could be wrong. I've had most of the rear suspension off recently and installed new springs and drop links. I've checked u joints and drive shaft bolts are tight, so I'm thinking its a bad mount. Anyone else experienced this? many thanks Link to comment Share on other sites More sharing options...
Zed Head Posted September 17, 2016 Share #2 Posted September 17, 2016 The nose of the diff lifts during acceleration then drops down when throttle is let off. The knock could be the metal on the front of the mount coming down on the cross member. If you look closely you'll see that the gap there is pretty small. There's actually a specification for the space between the top and bottom metal plates of the diff mount. Might be worthwhile to remove it and measure. You can also take a large screwdriver and pry the two plates apart while it's out to see how weak it is. You might find that it's about to fall apart. Picture from 1976, it's clearer. Link to comment Share on other sites More sharing options...
maton_acoustic Posted September 21, 2016 Author Share #3 Posted September 21, 2016 Funnily enough, there wasn't a nut on that front insulator. Oops! thanks for the help Link to comment Share on other sites More sharing options...
Zed Head Posted September 21, 2016 Share #4 Posted September 21, 2016 That nut is hard to see. The strap probably got a workout. Link to comment Share on other sites More sharing options...
