are headbolts interchangable?
Znut73
The bolts are all the same in the L series and the torque specs are the same for all non-turbo engines. The Turbos' had a different head bolt which could be torqued about 10% more than stock, and you can use these in any of the L series engines as well. They are about 60 bucks for a set if you wanted them.
Clean them with a wire brush by hand, or on a drill or bench grinder, whichever you have. When you are ready to install them, put a little engine oil on the threads before you put them in the block to keep the bolts from seizing, but the biggest advantage you will get is a more accurate torque setting with them if they are lubricated.
2ManyZs - Shouldn't a high tempature antiseize be used?
I would think that a little oil would burn in there, and if removed again later, would make them all look like the ones that come out next to an exhaust port.......no??
- Jeff
You can use high-heat anti-sieze..
But, there are engine builders who will swear that anti-sieze will do the same thing and others that will tell you that the anti-sieze is not good when used on an engine where you have steel, cast iron, aluminum in contact with one another as well...:ermm:
The best thing I can say is use a little anti-sieze on the threads only, and use a little oil under the head of the bolt for lubrication when it comes in contact with the head, so you get a true torque reading. I'd prefer not having any anti-sieze not getting into the oil if at all possible.
Guess it all boils down to personal preferrence.
