sweatybetty Posted September 25, 2016 Share #1 Posted September 25, 2016 i would like to use a light-weight flywheel, but the vendors say you have to use a certain clutch. my question is, why wont a factory style clutch work with a light-weight flywheel? anyone done it? thanks all sb Link to comment Share on other sites More sharing options...
Jeff G 78 Posted September 25, 2016 Share #2 Posted September 25, 2016 (edited) I don't have a direct answer, but I sent my race car's flywheel to Top End Performance and had them lighten it. I recall that they took about 9 lbs. off going from 25 to 16. I installed a new OE spec Exedy clutch and it works great. My engine makes around 200 HP at the flywheel. It has about 20 road race hours on it and everything is good. I think they charged about $175 plus return shipping at the time or something like that. It was well cheaper than buying an aftermarket flywheel. UPDATE: I just checked TEP's website to verify my numbers and their long-time machinist died unexpectedly last week. They are no longer offering flywheel lightening. I'm sure you could find a local machinist who could lighted your flywheel. The prints are available on the internet for the cut pattern. Edited September 25, 2016 by Jeff G 78 Link to comment Share on other sites More sharing options...
gundee Posted September 25, 2016 Share #3 Posted September 25, 2016 1 hour ago, sweatybetty said: i would like to use a light-weight flywheel, but the vendors say you have to use a certain clutch. my question is, why wont a factory style clutch work with a light-weight flywheel? anyone done it? thanks all sb I installed a Centerforce clutch kit with my aftermarket light flywheel. Never any problems with mine. Not sure what they are refering to. Link to comment Share on other sites More sharing options...
Zed Head Posted September 25, 2016 Share #4 Posted September 25, 2016 Probably depends on the vendor and how they drilled and machined the flywheel. Link to comment Share on other sites More sharing options...
