I've been searching through slot of threads on info about using the Rota rb 17x7.5 4mm wheels.  All I've found is were someone randomly mentions them, not much info. I have a stock 73 240z, no flares.  I was wondering if theses would fit with no rubbing issues? And if so what size tires would a guy want to use? I don't want to have the tires sticking out or have a stretched tire look.  Any info would be great. Thanks guys!
https://www.classiczcars.com/forums/topic/56260-17x75-4mm-rota-rbs-help/
Some guys go with 17's but it is really pushing it and you would have to have stretched tires.
There is some very good info in this thread on 16's,
  • 4 weeks later...
Regarding 17" wheels....I have 17x8 front and 17x9 rear. 215-40 front and 235-40 rear on a lowered series 1 with no issues. With the correct offsets and adjustable camber plates it works. The rear tire is really close to the fender!!! Some 235-40s are a tad wider than others and may rub slightly. See my photo album pics. The front set-up clears just fine. The wheels you see in my album have alot of offset and required me to fab custom width spcares and longer studs. It was work but I like the results! Just one man's opinion!
  • 3 months later...
where can we find pics of your car? what's the offset of the wheels F/R?
Sent from my LG-D850 using Classic Zcar Club mobile
My car is on the rotisserie right now so no wheels yet, but I am in the planning stages for the wheels and tires. I am thinking of a factory order for the RB 16" wheels myself. I need the 5 x 114.3 lug pattern though.
This is the look I'm going for though.
IMG_4268.thumb.JPG.5bae9606a3a403b652441
  • 1 year later...
