Need help. New member. Installed mega squirt2
Dsa_z32
Hello everyone. I'm new to this forum. I bought a 77 280z with the stock l28. The guy I bought it from installed a megasquirt2 in the car. I got the car started and idling. Was wondering if anyone has a good map for the stock l28 NA for the 280z
The turbo is not really the issue since all it does is change intake manifold pressure.  It's the ignition system, injectors, sensors, etc., that matter.  If you have the same components as a turbo engine but no turbo then a map for a turbo engine will probably work fine.  Megasquirt will never use the boost part of the map.  You just need a list of the parts controlling the engine to find the right map, for starters.
Pretty sure it's fairly easy to scale the injector duration up after you correct the injector flow rate.  There might even be an auto-scale function in MS.  The one thing that everyone who runs Megasquirt eventually agrees on, is that every map is different.
But really, this is not a Megasquirt forum.  Madkaw is the only guy on here that is using it I think.  You want to be on Hybridz.org or one of the Megasquirt support forums.  This site is good for everything else though.
I have no done fuel as of yet- so can't help you with it. After I got my ignition set up running I haven't been studying the manual. I believe Zed is correct that you just set up the AFRs and let the ECU do the rest. There's a whole sub forum on MegaSquirt on hybridz
Sent from my iPhone using Classic Zcar Club
  • Who's Online   1 Member, 0 Anonymous, 833 Guests (See full list)
