October 10, 20168 yr comment_504687 The circlip is removed when disassembling the pump. Blue posted a video a while back about rebuilding water pumps. The mechanic shows it in that video Link to comment https://www.classiczcars.com/forums/topic/56316-water-pump/?&page=2#findComment-504687 Share on other sites More sharing options...
October 11, 20168 yr comment_504699 Here's an informative video I found while looking for Blue's. Couldn't find his. I have an old leaking pump but it doesn't have the spring clip. 9011-12 is the number on it. Don't know if it's Nissan or aftermarket. https://www.youtube.com/watch?v=U1x3-R2l03Q Link to comment https://www.classiczcars.com/forums/topic/56316-water-pump/?&page=2#findComment-504699 Share on other sites More sharing options...
October 11, 20168 yr comment_504703 Check this out. Zoom in and you can see the spring clip. There must be something out there for the L24, 26 and 28. Hard to beat $20 for a fresh AZ pump though. http://www.ebay.com/itm/Water-Pump-Rebuild-Kit-FOR-Nissan-Datsun-1600-Bluebird-P510-L13-L16-1967-Onwards-/281852998385 Link to comment https://www.classiczcars.com/forums/topic/56316-water-pump/?&page=2#findComment-504703 Share on other sites More sharing options...
October 11, 20168 yr Author comment_504708 Friend of mine says made in China junk. Think I will be packing spare (to go along with my ECU and Ign module). Its a pretty simple device so not sure what would make it poor quality unless its just low quality bearings/seals or bad QC of the finished good. New to the car game, did some research on the old interweb, yikes a LOT of talk about water pumps, country of origin, QC, you name it there is several opinions going in several directions. Anyway I will report back on how THIS water pump works out so I can add to the chorus of noise. Edited October 11, 20168 yr by Dave WM Link to comment https://www.classiczcars.com/forums/topic/56316-water-pump/?&page=2#findComment-504708 Share on other sites More sharing options...
October 11, 20168 yr Author comment_504750 I discussed it with my friend some more, he says I should be ok going aftermarket considering how little I drive it. I have NO exp with aftermarket pumps, but I have to assume Nissan no longer supports something this old. Link to comment https://www.classiczcars.com/forums/topic/56316-water-pump/?&page=2#findComment-504750 Share on other sites More sharing options...
October 12, 20168 yr comment_504789 You mentioned your concern about snapping a retaining bolt during the process of removing the water pump. As I remember those bolts are pretty small and buried in the block. I've had my Z 40 plus years and over thirty years ago had to replace the water pump. Yeah, one of the bolts snapped off! There was no way I was going to be able to extract the bolt so I thought what the hell I'll give it a shot and replace the pump minus one bolt. Well guess what? All these years and she has never leaked. Another one of the reasons I love my Z! Link to comment https://www.classiczcars.com/forums/topic/56316-water-pump/?&page=2#findComment-504789 Share on other sites More sharing options...
October 12, 20168 yr comment_504797 Similar story here except for the time since replacement, I snapped a bolt on my Z's water pump when replacing it a few years ago and have been driving it all over, no leaks. I put anti seize on the bolt threads when they went back in (can't remember if I used new bolts). Edited October 12, 20168 yr by Mikes Z car Link to comment https://www.classiczcars.com/forums/topic/56316-water-pump/?&page=2#findComment-504797 Share on other sites More sharing options...
October 12, 20168 yr Author comment_504799 that snapping is what I kept reading about, I got lucky they came out easy, and I did use anti seize for replacement. Only odd thing was the locating dowel holes on the AZ pump were oversized, so the dowels did not really locate it. I guess there could be an issue with the fitment of the vanes to the cover, but it all worked ok. Link to comment https://www.classiczcars.com/forums/topic/56316-water-pump/?&page=2#findComment-504799 Share on other sites More sharing options...
