blodi Posted August 1, 2017 Author Share #73 Posted August 1, 2017 Did a couple more logs just to double check where I'm at...this is with 165/215: 7-31-17-1 by blodi, on Flickr 7-31-17-2 by blodi, on Flickr Link to comment Share on other sites More sharing options...
240260280 Posted August 1, 2017 Share #74 Posted August 1, 2017 Looks like it dropped a bit richer or tester is offset. In previous run posted on July 9 you are peaking ~ 13.5. The last plot is the same shape but peaking ~13.1. Try drilling out unused air correctors with 3/32" bit and give it a run at 165/238. We need a crowbar to straighten that top end! Link to comment Share on other sites More sharing options...
blodi Posted August 2, 2017 Author Share #75 Posted August 2, 2017 Ok, i took my 195 correctors and drilled them to "238". Unfortunately its supposed to rain the next few days, but I'll let you know when I get it out and get a log. Link to comment Share on other sites More sharing options...
240260280 Posted August 2, 2017 Share #76 Posted August 2, 2017 This should be interesting~ Hopefully the high end will rise nicely. Link to comment Share on other sites More sharing options...
Duffman Posted August 2, 2017 Share #77 Posted August 2, 2017 Gentlemen, stupid question, how are you putting these graphs together? Are you attaching something to your AFM? I don't know if you are just taking readings and putting the graphs together, or creating them directly from AFM. I want to create my own. Love the thread! Link to comment Share on other sites More sharing options...
blodi Posted August 2, 2017 Author Share #78 Posted August 2, 2017 1 minute ago, duffman said: Gentlemen, stupid question, how are you putting these graphs together? Are you attaching something to your AFM? I don't know if you are just taking readings and putting the graphs together, or creating them directly from AFM. I want to create my own. Love the thread! I have an Innovate LM-2 that is hooked up to a wideband sensor in my collector. The Innovate has a logging function that you can then pull up on their software on the computer. It's not cheap (~$240) but the information is priceless. Link to comment Share on other sites More sharing options...
Duffman Posted August 2, 2017 Share #79 Posted August 2, 2017 Thanks for the info, might have to look into getting one! Link to comment Share on other sites More sharing options...
blodi Posted August 3, 2017 Author Share #80 Posted August 3, 2017 OK....165/238.......that flipped it around..... 8217 by blodi, on Flickr Thinking 165/225? Link to comment Share on other sites More sharing options...
240260280 Posted August 3, 2017 Share #81 Posted August 3, 2017 (edited) Excellent data! Nice to see a crowbar at work and the high end raise! I agree 165/225 should flatten it and give ~12.5 +/- 0.5. You could then try 160 fuel if you want a tic leaner. There also seems to be a big change in the low end of the latest plot. It does not dive rich like it has done but instead it jumps lean. What is your A/F when you cruise at 60mph now? We may have to keep an eye on this region. Edited August 3, 2017 by 240260280 Link to comment Share on other sites More sharing options...
240260280 Posted August 3, 2017 Share #82 Posted August 3, 2017 Once you get the mains sorted did you want to circle back to accelerator circuit? Link to comment Share on other sites More sharing options...
blodi Posted August 3, 2017 Author Share #83 Posted August 3, 2017 2 hours ago, 240260280 said: Excellent data! Nice to see a crowbar at work and the high end raise! I agree 165/225 should flatten it and give ~12.5 +/- 0.5. You could then try 160 fuel if you want a tic leaner. There also seems to be a big change in the low end of the latest plot. It does not dive rich like it has done but instead it jumps lean. What is your A/F when you cruise at 60mph now? We may have to keep an eye on this region. Ordered some 225's...we'll see where that lands. I notice the lean jump on this one too at the beginning....odd. I took two other logs last night as well...they were similar. I didn't get a good eye at cruise....it's always been good at cruise in the past. I'll check it again. 2 hours ago, 240260280 said: Once you get the mains sorted did you want to circle back to accelerator circuit? Yeah, we'll come back to that...not sure where to go with it now seeing how it changed with that last run. Link to comment Share on other sites More sharing options...
Duffman Posted August 3, 2017 Share #84 Posted August 3, 2017 I found out my AEM AFR meter (#30-4110) has the analog output capability for data logging, look forward to see how my numbers look in graph format! So much tweaking, so much fun!! 1 Link to comment Share on other sites More sharing options...
