Weber selection and initial jet tuning
blodi
Yes me too. Even though I have Mikuni's. The only thing I noticed was in all the years I have talked to others about
Weber and Mikuni, I have never run into anyone say they were using a air jet over 200. I must have missed something along the way.
Otherwise they would not make them I guess.
On 8/18/2018 at 5:40 PM, 240260280 said:
@blodi
Heads Up!  F19 tubes enroute to you from Europe ?
Thanks! Looking forward to seeing the difference.  Glad to know so many others are learning from this thread.  Hopefully it helps others in the future too.
Ok, got 4 logs in today and I also managed to get the RPM sensor working!  I noticed though that the revs read about ~800 rpm lower on the logger than the tach....not sure which is correct. I rev to 7K when I test on the tach. Maybe tach needs adjustment? Dunno.
F16 155/215...I didn't have 160's.....but looks like that might be the sweet spot between the 155 and 165.......First run was in the morning...last 3 were in afternoon with a bit higher temps.
44157398002_a6c9237865_o.jpg82218-1 by blodi, on Flickr
43299598415_295dd49d27_o.jpg82218-3 by blodi, on Flickr
43487612214_b65b7deda3_o.jpg82218-4 by blodi, on Flickr
A couple side notes. I noticed the cruise has now been very rich. I believe this is due to the 70 idle jets. I am going to go back to the 65's to confirm that is the issue.
Also, after inputing my info into this gear ratio calculator; https://www.blocklayer.com/rpm-geareng.aspx
I do believe my tach is reading high and the data logger is correct. So I will try to dial that in as well.
  • Who's Online   2 Members, 0 Anonymous, 566 Guests (See full list)
