Weber selection and initial jet tuning
blodi
You know this thread started Oct 2016... two years of work, down time for the head problems, so many runs and Etube changes and we finally seem to have nailed the 45DCOE on larger L engines.
Perseverance and finally a gift to the Z folks out there! F19 eTubes are the cat's meow! ??
Cheers and a big thanks for your hard work! :beer: YIPEEE YAAAAHOOOO
Two coats on the dining room and Janet is happy!
The only thing left to play with is to mess with the acceleration circuit as you see fit.
You can try to quench that common lean gasp at the start. You know the parts and what they do so I'll leave it to you now that you are a Weber Experten! ?
Edited by 240260280
F19  165/175
Range of 1.7 points.
Note: this is close (but better) than the elusive June 28, 2017 plot that suddenly went too rich on subsequent runs. It was never repeated. The configuration then was (F16 165/215).... so the F19 runs leaner than the F16 and needs a smaller air corrector.
Edited by 240260280
