January 5, 20205 yr Author comment_590395 Yeah, that's kind of what I went through back in August.....I had the dizzy installed and bypassed the resistor as instructed...my tach was all bouncy at higher rpm. So I tried hooking the resistor back up and that's when it fried the ignition module on the dizzy. Maybe I need a different coil? I thought I had the correct ohm version...but now I forget what I have in there. I'll have to check. Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=40#findComment-590395 Share on other sites More sharing options...
January 5, 20205 yr comment_590400 Should be 1.5 for the zx. 3.0 for the z. I run a Crane Fireball PS20. Seems perfect for the last 3 or 4 years? Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=40#findComment-590400 Share on other sites More sharing options...
January 6, 20205 yr Author comment_590418 5 hours ago, siteunseen said: Should be 1.5 for the zx. 3.0 for the z. I run a Crane Fireball PS20. Seems perfect for the last 3 or 4 years? Do you have the ballast resistor hooked up with your setup? Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=40#findComment-590418 Share on other sites More sharing options...
January 6, 20205 yr comment_590435 Nope. Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=40#findComment-590435 Share on other sites More sharing options...
January 6, 20205 yr comment_590444 Here's mine. If you need more let me know. And the reason my wires are different colors than the instructions above is I found a ZX in a junkyard. Got the dizzy adapter and about 4ft. of the ZX wiring harness then spliced it into the 240's wires. Â Edited January 6, 20205 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=40#findComment-590444 Share on other sites More sharing options...
April 19, 20205 yr Author comment_597524 Happy new year and happy uh quarantine to everyone.  So, I’m trying to figure out my high rpm sputter.  You can see it do it on the dyno video I posted last year.  Tried a new coil, wires, put in a new pertronix...nothing.  Fuel pressure is steady at 4 psi. Pulled the tops off the carbs and everything looks clean. Maybe it’s the plugs?  What plugs/gap should I be running on this setup? Currently running NGK BPR6ES at about .029 gap.    Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=40#findComment-597524 Share on other sites More sharing options...
April 19, 20205 yr comment_597527 On 7/16/2019 at 8:02 AM, jonbill said: I used to use a pertronix igniter and it had similar misfire problems over 6k. I'd try a 280zx distributor if you can borrow one from somebody near. I also tried a new Pertronix igniter. I concluded they don't do revs. Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=40#findComment-597527 Share on other sites More sharing options...
April 19, 20205 yr comment_597530 It could possibly be a noisy alternator or Vreg exhibiting +12V bus problems at higher rpms. Â Â Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=40#findComment-597530 Share on other sites More sharing options...
April 19, 20205 yr Author comment_597533 22 minutes ago, 240260280 said: It could possibly be a noisy alternator or Vreg exhibiting +12V bus problems at higher rpms.   I have the MSA upgraded alternator with the internal voltage regulator.  I guess I could monitor the voltage gauge.  Never had a problem with the pertronix reviving in the past.  She’d gladly run up to redline all day.  Going to order up some new plugs. Is what I currently have good?  Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=40#findComment-597533 Share on other sites More sharing options...
April 19, 20205 yr comment_597537 Yes they seem fine for plugs. You can check ignition in dark to see if wires are arcing. I had brand new Bosch wires do this on my Rav.... Made in China of course. Some spray salt water mist on wires but that is not nice on a non-beater engine.  Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=40#findComment-597537 Share on other sites More sharing options...
April 25, 20205 yr Author comment_598019 I put in new plugs and she certainly revs better. But breaks up now at 6k instead of 5k before.  I might try adding timing to see if it has an impact.  Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=40#findComment-598019 Share on other sites More sharing options...
April 25, 20205 yr comment_598022 what sort of spark plug gap are you using? You could try closing them down to 0.6mm. Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=40#findComment-598022 Share on other sites More sharing options...
