January 13, 20187 yr Author comment_539619 Glad others are all getting something out of this! Started this just to educate myself, but happy others can learn with me!  esmit208, I don't know if my tuner has an altimeter, but I'll look. It was varying temps when I did various pulls, so I always kept that in mind. I think we are between the last two setups as far as e tubes and such...then just figuring out the accell circuit.  Hopefully tuning can resume March/April once the snow here in Michigan clears. In the meantime I have plenty to do: lash pad fix, rear disc conversion, some small electrical fixes...etc. Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=17#findComment-539619 Share on other sites More sharing options...
January 13, 20187 yr comment_539630 Blodi, you need a skidoo! Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=17#findComment-539630 Share on other sites More sharing options...
January 13, 20187 yr comment_539637 12 hours ago, blodi said: Glad others are all getting something out of this! Started this just to educate myself, but happy others can learn with me!  esmit208, I don't know if my tuner has an altimeter, but I'll look. It was varying temps when I did various pulls, so I always kept that in mind. I think we are between the last two setups as far as e tubes and such...then just figuring out the accell circuit.  Hopefully tuning can resume March/April once the snow here in Michigan clears. In the meantime I have plenty to do: lash pad fix, rear disc conversion, some small electrical fixes...etc. Your local weather channel broadcasts the current barometric pressure (altimeter) during the local weather. They present it in INCHES OF MERCURY.......29.96......29.94....etc...etc. This setting is very important in aviation. Without it a pilot will not know his correct altitude. Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=17#findComment-539637 Share on other sites More sharing options...
January 26, 20187 yr Author comment_540860 Got the 175's machined down to 170. Popped one in last night...should be all good to go!.....well...in a couple months once I get everything else done on the car and it's warm/dry enough. Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=17#findComment-540860 Share on other sites More sharing options...
February 23, 20187 yr Author comment_543085 Still haven't driven the car anymore, but the weather is just starting to turn it seems. I did rig up my chokes finally. Went to the local hobby shop and got about $15 worth of R/C airplane linkage parts and it seems to work pretty good! IMG_4474 by blodi, on Flickr IMG_4476 by blodi, on Flickr  Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=17#findComment-543085 Share on other sites More sharing options...
February 23, 20187 yr comment_543093 Looks GREAT! SK's have an accelerator pump, no choke. Let us know how the choke mechanism works. Fortunately here in Florida, at least central Florida, not too many cold morning starts to evaluate the accelerator pump. STAY ON IT! Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=17#findComment-543093 Share on other sites More sharing options...
February 23, 20187 yr comment_543094 Looks great! Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=17#findComment-543094 Share on other sites More sharing options...
February 28, 20187 yr Author comment_543431 60+ degree day here yesterday so I fired her up after work. The new choke setup works great! Started immediately. Backed it out the driveway....thought I started hearing that tapping noise again...got a bit down the road and could hear it wasn't hitting on all cylinders..... Later on I pulled the valve cover and ...son of a.....it happened again! IMG_4498 by blodi, on Flickr Found the lash pad...full in tact this time... IMG_4499 by blodi, on Flickr  Really confused what might be causing this. I readjusted the valve to .010 when I installed the new lash pad. A quick look has me wondering if the lash pad on this particular valve is thinner than the others.... IMG_4501 by blodi, on Flickr IMG_4500 by blodi, on Flickr I think I'll pull one of the other lash pads and measure it. Maybe when this engine was built a thinner last pad accidentally was installed on this valve. It would still be a bit odd as I had put 3-4k miles on this engine before it had issues. And regardless of the thickness the pad still sits down into the retainer the same amount. What else could cause the lash pad to pop out? Sticky valve? The engine has only the 3-4K I've put on it since it was built and has had a generous amount of oil changes. Maybe I didn't get the spring that holds the rocker valve in place on correctly? I'm just stumped a bit. Ideas?     Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=17#findComment-543431 Share on other sites More sharing options...
February 28, 20187 yr comment_543439 Aftermarket lash pads are flat on bottom, Nissan's have a hole the valve stems fits in. Is your's flat or does it have the hole? Another thing I've seen on this forum is the mouse trap springs hooked in the wrong way. My dementia is iffy today but i think it was one of @240260280 friends, Kammy? Just some guesses, also some write ups that may be useful. https://www.google.com/search?rlz=1C1BOFA_enUS494US494&ei=-OCWWqiYCYLisAWuk5PYDw&q=lash+pad+fell+off+classiczcars.com&oq=lash+pad+fell+off+classiczcars.com&gs_l=psy-ab.3...55397.67929.0.69656.49.31.2.0.0.0.126.2114.30j1.31.0....0...1c.1.64.psy-ab..24.1.84...0j0i7i10i30k1j0i7i30k1.0.cwiVEIcihMo Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=17#findComment-543439 Share on other sites More sharing options...
February 28, 20187 yr comment_543440 Quite worrysome. I would consult a DATSUN/NISSAN professional on this one. Let us know what solution you come up with. Much luck! Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=17#findComment-543440 Share on other sites More sharing options...
February 28, 20187 yr comment_543441 This is the same valve as last time? Hmmmm. Interesting. I don't see anything obvious. The wipe pattern on rocker arm looks real good. Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=17#findComment-543441 Share on other sites More sharing options...
March 1, 20187 yr comment_543475 Check the wipe pattern as a first step. If ok then pull plugs and use remote starter to crank while you watch valves move, Link to comment https://www.classiczcars.com/forums/topic/56375-weber-selection-and-initial-jet-tuning/?&page=17#findComment-543475 Share on other sites More sharing options...
