moelk Posted June 14, 2019 Share #409 Posted June 14, 2019 9 minutes ago, blodi said: Going to the dyno on Monday finally. I'll be sure to post the results. Car has been running great! Looking forward to it. Link to comment Share on other sites More sharing options...
240260280 Posted June 14, 2019 Share #410 Posted June 14, 2019 Ditto. Glad it is working well and it will be nice to see the numbers. Also a useful data set would be to record a street run using your A/F meter before or after the dyno run then compare to what the dyno a/f gives. You may want to bring a selection of main jets to move the a/f up or down at the dyno. If you have lots of time and runs, a comparison of F16 Etube vs F19 E tube with same air and fuel jets would be useful to see if F19 is "the one". Link to comment Share on other sites More sharing options...
240260280 Posted June 14, 2019 Share #411 Posted June 14, 2019 (edited) Just another thought. What is the cam sprocket set to on your Z? I wonder if moving it will affect rich dip (possible exhaust event cause) at onset of run? It could be something to play with this summer to completely flog this horse! Edited June 14, 2019 by 240260280 Link to comment Share on other sites More sharing options...
blodi Posted June 14, 2019 Author Share #412 Posted June 14, 2019 I just have it scheduled for two power pulls. To do any tuning you need to rent the dyno for like half a day $$$. Cam sprocket is stock and non adjustable. Link to comment Share on other sites More sharing options...
240260280 Posted June 14, 2019 Share #413 Posted June 14, 2019 Super. For the cam sprocket, is it on position 1,2 or 3? Link to comment Share on other sites More sharing options...
blodi Posted June 14, 2019 Author Share #414 Posted June 14, 2019 I didn't realize there were different positions. Link to comment Share on other sites More sharing options...
blodi Posted June 14, 2019 Author Share #415 Posted June 14, 2019 (edited) Now I found this info....I had no idea.....interesting.... https://www.zcar.com/forum/10-70-83-tech-discussion-forum/125282-cam-timing.html I can try to take a look this weekend. Edited June 14, 2019 by blodi Link to comment Share on other sites More sharing options...
240260280 Posted June 14, 2019 Share #416 Posted June 14, 2019 BE CAREFUL. Chain tensioner must not pop out! http://atlanticz.ca/zclub/techtips/timing/mechtime.html Link to comment Share on other sites More sharing options...
blodi Posted June 18, 2019 Author Share #417 Posted June 18, 2019 I got bumped from the Dyno until next Saturday now. Still haven't had a chance to look at the cam position. I do have a timing chain wedge tool if I do get a chance to look at it. Link to comment Share on other sites More sharing options...
blodi Posted July 13, 2019 Author Share #418 Posted July 13, 2019 Results are in! 195 rwhp and 175 Rwtq. Stock engine/carb setup made 128 rwhp on the same dyno 3 years ago. It was breaking up a bit at the top end. Not sure if that is from fuel or ignition. I’m not running a return line from the carbs...should I? Or do I need an MSD or something ? Just running a perteonix electric point conversion. I still need to download the logs from the wideband. 330DCAB8-2A0E-4588-87DB-92005E03940D.MOV Link to comment Share on other sites More sharing options...
240260280 Posted July 14, 2019 Share #419 Posted July 14, 2019 Weird, I was just thinking of you and this earlier today. Must have been ths Z FORCE. 195RWHP is F'n AWESOME!!!!! For the high RPM scatter, usually a distributor refresh with lube can help the high end. Sometimes the spindle teeth meshing with the worm on crank snout cause timing variation at high rpms according to Frank Honsowetz. He recommends brass teeth. Also it could be poor electronic components in the Pertronix. Link to comment Share on other sites More sharing options...
240260280 Posted July 14, 2019 Share #420 Posted July 14, 2019 Did the Dyno use a wideband? It would be interesting to compare. I wonder where you can get 5 more HP? Link to comment Share on other sites More sharing options...
