Powering sensor signal
grannyknot
I'm installing a vacuum pump to supply the brake booster with vacuum, it came with a sensor that detects low vacuum that triggers power to the the vac pump. I'm not at all sure if this sensor requires power to make it work or if it simply supplies power to the pump by a switch that is activated by low vac.
Anyone have experience with these kinds of sensors?
Thanks,
Chris
