I'm having trouble finding a simple answer (maybe there isn't one?) to the question of: are the L8 and L4 stamped transmissions exactly the same? The problem trany is in a 81 zx Base and the donor was in a 80 zx non turbo. Base has the L4 and the donor is stamped L8? Any help appreciated.
Chuck
80 and 81 could have different ratios.  There's also a reverse lockout mechanism that was introduced about that time.  Generally, the casting numbers and letters have been found to have little meaning, despite conjecture about date codes and stuff.  I have five.  Nobody has shown that they could take a casting number and actually use it for some specific purpose, that I've seen.
To add to ZH's post above the O/D (5th) ratio is slightly different as shown in the far right column.  1st thru 4th is the same.
Just FYI.......
280 ZX (8/79-6/80) FS5W71B
5 spd "B" type
3.062 1.858/39% 1.308/30% 1/24% 0.773/23%
280 ZX (7/80-6/83) FS5W71B
5 spd "B" type
3.062 1.858/39% 1.308/30% 1/24% 0.745/26%
Once again I thank you TZ for the input. This Z is my first attempt at an auto resto project. What can I say, I'm 65 and it was on my bucket list! I am amazed at the amount of info available on this site from its members and their willingness to help. Thanks to all of you.
