That jegs link is pretty much what i ordered.  If you look closely the mounting tabs are in the center of the unit, not the edges.  To squeeze it between the radiator tabs i used some basic standoffs.. I am extremely happy with the results
  On 11/15/2016 at 4:56 AM, Mike said:
Alan, any chance these are still available in Japan or elsewhere?
Mike
These are very hard to come by, Mike. It took me a few years to find the one in my photos...
Your best bet would be Yahoo Japan auctions, but they usually change hands for $$$$. If strict originality is not important then you might be able to find a similar setup (slightly different mounting bracket) on a full size sedan of a similar age, like a 130-series Cedric for example.
A slightly left-field suggestion would be to look at the setup on a Triumph Stag (no, really...). A fairly similar bottle with a mounting bracket that can be modified to make it bolt into the same pre-drilled holes on the front of the radiator core support that the PS30/PS30-SB overflow bottle fits. Still available new from the major British car parts suppliers like Moss Motors. Just don't tell anyone where it came from...
