Posted December 3, 20168 yr comment_507390 changed out the brake booster. old one was corroded Sent from my LG-D850 using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/56618-update-on-my-75-280z/ Share on other sites More sharing options...
December 3, 20168 yr Author comment_507391 also discovered an exhaust manifold leak so here is the current situationSent from my LG-D850 using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/56618-update-on-my-75-280z/#findComment-507391 Share on other sites More sharing options...
December 3, 20168 yr Author comment_507392 Sent from my LG-D850 using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/56618-update-on-my-75-280z/#findComment-507392 Share on other sites More sharing options...
December 3, 20168 yr Author comment_507393 but now I have to wait for a new gasket to arrive. the one I ordered was delivered in bubble wrap, so suffice to say, it has bent and contorted beyond useSent from my LG-D850 using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/56618-update-on-my-75-280z/#findComment-507393 Share on other sites More sharing options...
December 3, 20168 yr Author comment_507394 what's the consensus on the benefit of headers? at this point it would be super easy to add them.Sent from my LG-D850 using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/56618-update-on-my-75-280z/#findComment-507394 Share on other sites More sharing options...
December 3, 20168 yr comment_507396 I have the MSA ceramic coated 6-1 on both my Zs and love them. Neater engine bay, less heat under the hood and the SOUND!!! pair that with the Premium 2.5" exhaust and it don't get much better. The heat reduction has been considered one of the better solutions to the EFI cars "hot restart" problem. I've never had it with mine but I also have an aluminium fuel rail that helps also. They'll have that stuff on sale for the holidays too. In my opinion throw their stud kit in the trash and use something better, Nissan still makes them for a bunch of other cars. My last rebuild I used the SS one's from zcardepot.com and am very happy with them. https://zcardepot.com/engine/exhaust/exhaust-manifold-stainless-steel-stud-kit-240z-280z.html Link to comment https://www.classiczcars.com/forums/topic/56618-update-on-my-75-280z/#findComment-507396 Share on other sites More sharing options...
December 3, 20168 yr Author comment_507398 so no need for a heat shield between your aftermarket headers and intake manifold?Sent from my LG-D850 using Z Car Club mobile app Link to comment https://www.classiczcars.com/forums/topic/56618-update-on-my-75-280z/#findComment-507398 Share on other sites More sharing options...
December 3, 20168 yr Author comment_507399 just checked my intake/manifold and it looks like it only requires 15 bolts. I guess the 17 piece kit is to accomodate other years?zcardepot.com/stainless-steel-bolt-kits/engine-kits/intake-and-exhaust-manifold-stainless-steel-stud-kit.htmlSent from my LG-D850 using Z Car Club mobile app Link to comment https://www.classiczcars.com/forums/topic/56618-update-on-my-75-280z/#findComment-507399 Share on other sites More sharing options...
December 3, 20168 yr Author comment_507401 Sent from my LG-D850 using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/56618-update-on-my-75-280z/#findComment-507401 Share on other sites More sharing options...
December 3, 20168 yr Author comment_507402 I make cardboard templates like these when I remove bolts from projects. keeps them in a reference pattern for reinstall. because we know bolt sizes are different for each locationSent from my LG-D850 using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/56618-update-on-my-75-280z/#findComment-507402 Share on other sites More sharing options...
December 3, 20168 yr Author comment_507403 easy pry with bar and a few taps with rubber mallet releases the exhaust manifold from the block.Sent from my LG-D850 using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/56618-update-on-my-75-280z/#findComment-507403 Share on other sites More sharing options...
December 3, 20168 yr comment_507404 On 12/3/2016 at 6:42 PM, FreshZ said: so no need for a heat shield between your aftermarket headers and intake manifold? Sent from my LG-D850 using Z Car Club mobile app Yeah I use both but had to trim the vertical one to fit over one of the primary tubes coming off the header, very little trimming just to keep it from touching and possibly rattling at some point. On that stud kit, I don't remember having any left over but that doesn't mean much. In my picture you'll see the shield notch and another place I forgot to mention, where the header touches the bell housing. Your's may not rub but mine did and I had to slightly grind the bell house to keep the header from touching. You need to run the shields or it'll melt your PCV hose, red with black marking on my picture. Link to comment https://www.classiczcars.com/forums/topic/56618-update-on-my-75-280z/#findComment-507404 Share on other sites More sharing options...
