December 13, 20168 yr Author comment_507986 I need a new one. My cable is full of gear oil. It's even dripping from where the cable meets the car body. I have the seal and o-ring for the pinion gear, just didn't want to drain the tranny to replace those if it wasn't needed. I think I just need to replace the one that goes into the cable end. The cable is wet with gear oil about 18" down the cable from the tranny. Link to comment https://www.classiczcars.com/forums/topic/56625-the-dreaded-oil-pan-pull/?&page=6#findComment-507986 Share on other sites More sharing options...
December 13, 20168 yr comment_508001 Our speedo housing is the same height as the fill hole so you won't loose any oil. If it's traveled all the way to the body you do need a new top hat. I read where one guy said his was so bad it dripped on his bare foot from under the dash. Said he thought it was a bee sting. I put teflon tape on my speedo housing's threads just as an extra precaution. Link to comment https://www.classiczcars.com/forums/topic/56625-the-dreaded-oil-pan-pull/?&page=6#findComment-508001 Share on other sites More sharing options...
December 13, 20168 yr Author comment_508013 2 hours ago, siteunseen said: I put teflon tape on my speedo housing's threads just as an extra precaution I wondered if that would work. Then I had a couple Arrogant Bastard Ale's and forgot about it . Edited December 13, 20168 yr by rcb280z Link to comment https://www.classiczcars.com/forums/topic/56625-the-dreaded-oil-pan-pull/?&page=6#findComment-508013 Share on other sites More sharing options...
December 13, 20168 yr comment_508014 when the ale is good you can't have just one!Sent from my LG-D850 using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/56625-the-dreaded-oil-pan-pull/?&page=6#findComment-508014 Share on other sites More sharing options...
December 14, 20168 yr comment_508018 Angry Bastard is my favorite. I used to think arrogant meant you had smelly armpits. Link to comment https://www.classiczcars.com/forums/topic/56625-the-dreaded-oil-pan-pull/?&page=6#findComment-508018 Share on other sites More sharing options...
December 14, 20168 yr comment_508043 14 hours ago, rcb280z said: I had a couple Arrogant Bastard Ale's You're not worthy. Link to comment https://www.classiczcars.com/forums/topic/56625-the-dreaded-oil-pan-pull/?&page=6#findComment-508043 Share on other sites More sharing options...
December 14, 20168 yr Author comment_508049 33 minutes ago, Captain Obvious said: You're not worthy. I know. But man they were good. Link to comment https://www.classiczcars.com/forums/topic/56625-the-dreaded-oil-pan-pull/?&page=6#findComment-508049 Share on other sites More sharing options...
