Triple Carbs - Weber vs Mikuna
wsmagers
We just bought a  1974 260z with triple carbs.  However, they are locked up and unusable.  Is there a solution to unlocking them?  Also, if we have to replace them, what is the difference in the Weber triple carb and Mikuna triple carb?
Unhook the linkage and try to move each throttle individually. Spray the crap out of them with your favorite goop.
I would say 95% chance they can be rebuilt. Mikuni or Weber? If Weber you can use Hypojets after the rebuild. Much more accurate adjustment.
  • Who's Online   1 Member, 0 Anonymous, 758 Guests (See full list)
