December 12, 20168 yr comment_507926 Yep, couple bucks at Homedepot. Link to comment https://www.classiczcars.com/forums/topic/56657-transmission-pull-question-280z/?&page=2#findComment-507926 Share on other sites More sharing options...
January 7, 20178 yr comment_509778 Good way to keep your trans oil inside for a couple of bucks is use a rubber cap from a hardware store.  Worked good for me when removing and pressure washing.   what size cap did you use? it would be nice to know, so whomever it is doing this next will have that cap ready to go during removal.Sent from my LG-D850 using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/56657-transmission-pull-question-280z/?&page=2#findComment-509778 Share on other sites More sharing options...
January 7, 20178 yr comment_509788 2 inch is what I have, it's a good tight fit.  two and a quarter inch would be perfect and would go all the way down and sit flat over the opening.  That one over the shift coupler is an inch and a half I believe. Edited January 7, 20178 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/56657-transmission-pull-question-280z/?&page=2#findComment-509788 Share on other sites More sharing options...
January 7, 20178 yr comment_509789 very useful infoSent from my LG-D850 using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/56657-transmission-pull-question-280z/?&page=2#findComment-509789 Share on other sites More sharing options...
