Can't tell you a brand but it looks like the flange isn't too thick for our cars. It needs to be the same thickness as the intake manifold so the yokes and bolts fit the same. Thinner flange would be more likely to warp or leak from all I've read.
so that wouldn't be a good header to use?
Sent from my LG-D850 using Classic Zcar Club mobile
If it's not about half an inch thick where you bolt it to the head you'll have to figure out how to make up the difference. MSA has it down pat. A good ceramic coated header is under $300 plus free shipping.  They have cheaper unpainted ones also. My opinion only, do what you want but I have them on both my Zs and couldn't be happier.
