Heater Core Alternative - Escort Core into 260/280
Captain Obvious
13 hours ago, HusseinHolland said:
 does this entire box attach to the one in your picture where the foam seal is located
Yes. This whole box:
Goes here:
Now... Since your car came from the factory without A/C, there is supposed to be a simple hollow duct box sitting there, but I don't know what they did for your aftermarket A/C.
  • Agree 1
Thank you - those make it very clear. I am thinking of buying a used factory AC box with evaporator, since every other part of the dealer AC install is sloppy, I can't imagine the evaporator install is any better. The issue there would be dealing with the factory line fittings. I have no idea if they are standard or some funky metric size/version fittings that will be difficult to find.
What exactly do you need measured? I have an evaporator sitting in my garage.
Do you have any typical fittings you could send me to test fit for you?
Hi Steve
Thank you for the offer. I think what I would need to explore this are the OD and thread pitch of the Male fitting and the ID of the Female fitting, where the lines exit the firewall, and the two male fittings on the Evaporator itself - if that's what you have handy. I took this image from the eBay listing. I need to establish if they are all metric or standard.
Judging from the other pics, the line fittings are flared (JIC perhaps?), which is not standard for any US type o-ring style fitting (MIOR, MOR, FIOR, FOR, etc.,)
This may not be worth the effort if I have to make lines that go into the casing to attach. I don't see any way to convert the outer fittings to o-ring style, unless someone sells repair ends that can be silver soldered to the existing hardlines. There are standard (#6, #8, #10) male & female flare beadlock fittings, but they will definitely be SAE thread, not metric.
Glad to help.
I've got factory A/C parts here available for purchase if you're interested. I'm a reasonable drive from you for something bulky, heavy, and expensive to ship. Wouldn't mind seeing one of your other project cars either.   LOL   Send me a PM.
On 4/13/2023 at 9:56 AM, Captain Obvious said:
Glad to help.
I thought of you this weekend as I was down in Philly with some Art Honor students, visiting PAFA & Philly Museum of Art. 😬
There is also a cool Sculpture park about 1/2hour North
Cool. Looks like you had a good time. And neat pics. Clear that you know what you're doing behind a camera. About the only thing I take pics of is cars or car parts. LOL
And I like the pic of that sculpture too. Looks like a nice Daydream.
  • Agree 1
  • 2 months later...
Took out the glovebox today, so I could see what's back there regarding the heater & AC
pulled the blower housing, made it very easy to access all the heater hoses. Needs a good clean anyway.
Heater core out.
bulkhead fitting removed, M4 rivnut in place to retain the AN line fitting
turns out the aluminum bracket/fitting has identical spacing to factory, makes things easier. Just have to drill the center hole to match the factory cover plate shown
All kinds of crusty 'plastic' laying in the box - it seems the heater core end tanks were encased in it
Edited by HusseinHolland
7 hours ago, HusseinHolland said:
Have to switch out the stock valve - it doesn't completely close - the hoses are still mildly warm, so coolant is still passing. Not going to work for me, will interfere with working AC once I get to that.
I installed an inline shut off valve on the in hose to the heater core, close it for the summer and open again for the fall, seem to work okay.
I recall reading at a couple of ppl have done so - I'm hoping that with a newer ball valve type, I won't need an auxiliary shut off. I could do that if there is no other way around it.
  • Who's Online   1 Member, 0 Anonymous, 885 Guests (See full list)
