Posted December 23, 20168 yr comment_508824 Does anyone know what I can buy as a replacement for this coil? I removed it from the power unit pcb. The schematic says it is 1.5 mh. I am not sure what the other markings mean. Link to comment https://www.classiczcars.com/forums/topic/56732-hitachi-radio-coil-replacement/ Share on other sites More sharing options...
December 23, 20168 yr comment_508832 I believe that is a capacitor, not a coil .1 micro Farad 50 Volt Film dielectric - probably polyester. Maybe polypropylene depending on where it was in the circuit. Link to comment https://www.classiczcars.com/forums/topic/56732-hitachi-radio-coil-replacement/#findComment-508832 Share on other sites More sharing options...
December 23, 20168 yr comment_508844 http://www.mouser.com/Passive-Components/Capacitors/_/N-5g7r Link to comment https://www.classiczcars.com/forums/topic/56732-hitachi-radio-coil-replacement/#findComment-508844 Share on other sites More sharing options...
December 23, 20168 yr Author comment_508864 Yes, I used the wrong word. It is a capacitor. Thank you for the help Link to comment https://www.classiczcars.com/forums/topic/56732-hitachi-radio-coil-replacement/#findComment-508864 Share on other sites More sharing options...
December 23, 20168 yr comment_508867 why are you replacing it? those caps rarely go bad. Link to comment https://www.classiczcars.com/forums/topic/56732-hitachi-radio-coil-replacement/#findComment-508867 Share on other sites More sharing options...
December 23, 20168 yr Author comment_508874 To be perfectly honest I screwed up and killed a fully functional radio. Now I am trying to troubleshoot it to get it working again and admittedly I am in over my head . Been trying to teach myself some things and searching the web hoping I can find the problem. When I was using the multi-meter last night it appeared that this component was not working properly. I realize now it is. Based on the schematic it looks like there is a coil before the fuse. I need to check that as I am not getting any voltage at the fuse. Link to comment https://www.classiczcars.com/forums/topic/56732-hitachi-radio-coil-replacement/#findComment-508874 Share on other sites More sharing options...
December 23, 20168 yr comment_508887 Is this the radio you messaged me about adding a din cable and this is a later 280z radio right? Which radio are you working on? I've rarely seen these copper coils by the fuse burn out. Do a continunity test on it to see if its bad. Edited January 13, 20178 yr by hr369 Link to comment https://www.classiczcars.com/forums/topic/56732-hitachi-radio-coil-replacement/#findComment-508887 Share on other sites More sharing options...
January 5, 20178 yr Author comment_509668 Happy new year!!! Thanks all for the help. to post an update. I am a total newbie and made a lot of mistakes but I am starting to see the light at the end of the tunnel. Here is how the mess happened, I was trying to find the hot wire going into the radio because I wanted to add a switch so I could go between the radio and the aux. Idiot that I am I didn't think and grounded the multi-meter to a painted surface. So it appeared no wire was hot, and then that's where it snowballed. I pulled the wires out of the plastic connector on the harness figuring I wasn't get a good connection for a reading. Before I did I marked them on a piece of paper. Now in hindsight marking top and bottom would have been useful and not using the letter b for blue and black would have been wise. Long story short whole radio opened up, resodering, breaking pieces and replacing them and finally figuring out the correct wire configuration. Now The radio tunes on both fm and am. But....there is an issue. I can only hear the radio at a very low volume ( volume control turned almost to 0). As soon as I raise the volume I hear a clicking noise. Rasing the volume control doesn't make the audio louder either it just starts this clicking noise. I know this is vague so I am uploading two videos. One you can hear the clicking and the other you can hear the audio. Does anyone know what I should do next? I don't know what would cause this. Link to comment https://www.classiczcars.com/forums/topic/56732-hitachi-radio-coil-replacement/#findComment-509668 Share on other sites More sharing options...
January 5, 20178 yr comment_509673 That cap you pulled off looks like the ones attached to the volume control. Perhaps you put that back on wrong. Take a picture of the cap you pulled off and put back on. Maybe i can see if its in the correct place. Edited January 5, 20178 yr by hr369 Link to comment https://www.classiczcars.com/forums/topic/56732-hitachi-radio-coil-replacement/#findComment-509673 Share on other sites More sharing options...
January 5, 20178 yr Author comment_509687 If you are looking at the back of the radio at he 6 pins ( 3 on top and 3 on the bottom) power goes to the top right pin and ground goes to the bottom left. I reversed these and then couldnt understand why the radio wouldn't turn on. The cap cap I took out was on the power unit pcb. C007 on the schematic. Do you think I have a bad cap connected to the volume pods? Link to comment https://www.classiczcars.com/forums/topic/56732-hitachi-radio-coil-replacement/#findComment-509687 Share on other sites More sharing options...
January 5, 20178 yr comment_509704 which wires are you using for speaker wires? is your speaker good? do you have another speaker to test it with? Link to comment https://www.classiczcars.com/forums/topic/56732-hitachi-radio-coil-replacement/#findComment-509704 Share on other sites More sharing options...
January 6, 20178 yr Author comment_509718 For the speaker wires I am using the 3 pins on the left. Vertical is ground and top and bottom correspond to left and right. I have the same issue using the car speakers that I do on the bench Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/56732-hitachi-radio-coil-replacement/#findComment-509718 Share on other sites More sharing options...
