Posted December 28, 20168 yr comment_509096 ok. I changed the manifold gasket on the 280z and buttoned everything up. But now I'm getting a hissing sound coming from what appears to be an area near injector #5.I double checked all the bolt connections, gasket and surrounding areas prior to installation. I started the car up and right away I hear hissing (vacuum leak sound) from injector 5 area. WTH can this be? Anyone else experience this? can the injectors get loose from the intake manifold removal process? Sent from my LG-D850 using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/56754-new-manifold-gasket/ Share on other sites More sharing options...
December 28, 20168 yr comment_509097 The FPR can make a hissing noise. Did you use new seals and insulators on the injectors, small and large (the round rubber pieces)? Are you using the two-screw clamps? They actually put some pressure on the lower seal by tightening on the top, big, insulator. Does it run like there's a vacuum leak? Link to comment https://www.classiczcars.com/forums/topic/56754-new-manifold-gasket/#findComment-509097 Share on other sites More sharing options...
December 28, 20168 yr Author comment_509101 I didn't remove the injectors when I removed the intake manifold. I kept everything intact as possible. I haven't taken it out of the garage since the manifolds were reinstalled. but it starts and idles fine. just has a hissing sound.Sent from my LG-D850 using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/56754-new-manifold-gasket/#findComment-509101 Share on other sites More sharing options...
December 28, 20168 yr comment_509102 Run the pump without the engine running and see if you can hear the hiss. Squirt some carb cleaner at the leak area and see if the sound changes. Grab the injector by hand and press it down and see if the sound changes. Pull the injector up and see if the sound changes. Lots of ways to learn more. Not uncommon for the seals to harden over time, then some bumping and moving can create a leak. Would have been super easy to replace the seals while the manifold was off. Still not that difficult. And they're cheap. I have a vague memory of writing this before. Link to comment https://www.classiczcars.com/forums/topic/56754-new-manifold-gasket/#findComment-509102 Share on other sites More sharing options...
December 29, 20168 yr Author comment_509128 good idea. I'll try that pump without starting and report back with my findings. As for the injector seals, I changed those all out a while ago when I put in replacement injectors.Sent from my LG-D850 using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/56754-new-manifold-gasket/#findComment-509128 Share on other sites More sharing options...
January 3, 20178 yr Author comment_509587 I just found the intake hissing leak. An egr delete was added, but has a bad seal. a little JBWeld should fix this. Crisis averted! I did in fact install all of the gaskets and head bolts properly....WhooHoo!!Sent from my LG-D850 using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/56754-new-manifold-gasket/#findComment-509587 Share on other sites More sharing options...
January 4, 20178 yr comment_509594 2 hours ago, FreshZ said: An egr delete was added How was this done? Don't remember what year 280 you have but here in CA you'll fail an emissions test with the EGR disabled. They check it on the '76 and on models. They checked function on mine. Edited January 4, 20178 yr by rcb280z Link to comment https://www.classiczcars.com/forums/topic/56754-new-manifold-gasket/#findComment-509594 Share on other sites More sharing options...
January 7, 20178 yr Author comment_509780 I have a '75. It started with a piece of printer paper to get initial shape, then moved to cardboard to get things tighter to the shape it should be, then finally to some aluminum flat stock and some gasket maker. left the studs in place in case the egr needs to be reinstalled at a later date.Sent from my LG-D850 using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/56754-new-manifold-gasket/#findComment-509780 Share on other sites More sharing options...
January 7, 20178 yr Author comment_509782 How was this done? Don't remember what year 280 you have but here in CA you'll fail an emissions test with the EGR disabled. They check it on the '76 and on models. They checked function on mine.I have noticed that it is hard to find a running '75 for sale in California. Sent from my LG-D850 using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/56754-new-manifold-gasket/#findComment-509782 Share on other sites More sharing options...
January 7, 20178 yr comment_509790 Yeah if you have a 75 you are safe for now, so to speak. Link to comment https://www.classiczcars.com/forums/topic/56754-new-manifold-gasket/#findComment-509790 Share on other sites More sharing options...
January 7, 20178 yr Author comment_509792 are there model year exempt changes in the works?Sent from my LG-D850 using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/56754-new-manifold-gasket/#findComment-509792 Share on other sites More sharing options...
January 7, 20178 yr comment_509803 3 hours ago, FreshZ said: are there model year exempt changes in the works? NOPE! And we have Schwarzenegger to thank for that when he was State Governor. Did away with the "Roll-over" I believe it was called. The '76 and '77 models were next to go to smog exempt until he stopped it. Link to comment https://www.classiczcars.com/forums/topic/56754-new-manifold-gasket/#findComment-509803 Share on other sites More sharing options...
