April 25, 20177 yr Author comment_519109 More updates from the paint shop.  This is looking really nice. Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=10#findComment-519109 Share on other sites More sharing options...
April 25, 20177 yr comment_519120 Nice! Looking good! Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=10#findComment-519120 Share on other sites More sharing options...
April 26, 20177 yr Author comment_519167 Started back on the motor assembly now that I have the engine bolts plated. Â Installed the timing chain cover, oil pump, water pump and oil pan. Â Will send the valve cover out tomorrow for the bead blast. Â Once that is done, the motor should be looking pretty nice and about ready to install when the time comes. Â Edited April 26, 20177 yr by motorman7 Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=10#findComment-519167 Share on other sites More sharing options...
April 30, 20177 yr Author comment_519485 Got the valve cover back today. Â Just have it resting on motor for now. Â Will clear coat tomorrow and then install. Â Will also trim those silly tabs off of the valve cover gasket. Â Whatever happened to the old fashioned cork gaskets? Â These new ones are funky. Â I would actually be interested in picking up a couple of the cork/brown ones if they were available. Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=10#findComment-519485 Share on other sites More sharing options...
May 1, 20177 yr Author comment_519608 Some detail pics of the valve  cover.  I think this came out real nice. Took my orange Z to the Motorcars on Main Street show in Coronado today.  Personally, I think it is one of the best car shows in San Diego.  The Z cars get a lot of attention. Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=10#findComment-519608 Share on other sites More sharing options...
May 2, 20177 yr Author comment_519695 Got the silver zinc parts back from the plater. Â The parts came out great. Â Before and after pics are below. Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=10#findComment-519695 Share on other sites More sharing options...
May 2, 20177 yr comment_519720 Do you have to do the clean up on them or do they take them as they were in the before picture? I have a bunch of stuff to get off to that shop. Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=10#findComment-519720 Share on other sites More sharing options...
May 2, 20177 yr Author comment_519736 1 hour ago, Montezuma said: Do you have to do the clean up on them or do they take them as they were in the before picture? I have a bunch of stuff to get off to that shop.  As far as the plating goes it's "Garbage IN, Garbage OUT". They need to be cleaned up but I think it is worth the work. Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=10#findComment-519736 Share on other sites More sharing options...
May 2, 20177 yr comment_519738 2 minutes ago, motorman7 said:  As far as the plating goes it's "Garbage IN, Garbage OUT". They need to be cleaned up but I think it is worth the work. Cool, I got a wheel just for this reason, I was just making sure. I actually enjoy taking a wheel to the parts...it is therapeutic. Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=10#findComment-519738 Share on other sites More sharing options...
May 2, 20177 yr Author comment_519762 1 hour ago, Montezuma said:  I actually enjoy taking a wheel to the parts...it is therapeutic. Yes it is Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=10#findComment-519762 Share on other sites More sharing options...
May 3, 20177 yr comment_519797 You mentioned Vise Grips... This is the only type of Vise Grip I've ever been able to get flair nuts out of the exhaust manifold with. Soaked them with Kroil for a couple days - then heated the manifold glowing red hot (acetylene gas torch) - locked these vise grips on the flair nut - and smacked them with a big brass hammer.  unscrewed them all - but even so, as you mention the threads on the flair nuts were so messed up, they weren't useable. I now have three sizes of these in the tool box..for flair nuts. The only thing better than a good Snap-On flair nut wrench. http://www.irwin.com/tools/locking-tools/the-original-locking-wrenches Wonder job - fun to watch it take form.. Edited May 3, 20177 yr by Carl Beck add info. Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=10#findComment-519797 Share on other sites More sharing options...
May 4, 20177 yr comment_519925 Those are excellent vise grips. I have a pair very good at holding onto stripped nuts Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=10#findComment-519925 Share on other sites More sharing options...
