July 17, 20177 yr Author comment_525891 Started putting the dash back back together. Did a a little clean-up on the gauges before installation. Also touched up a some of the chipped and scraped areas on the instruments. Trying to decide what to do about the non-working clock. I think I will send the clock out to this guy and get the quartz mechanism so it will last for a while and be accurate. http://www.zclocks.com/ Although, I am really tempted to try this: https://hyllest.wordpress.com/2014/09/28/quartz-clock-movement-into-a-240z-clock/ That might be worth my time. I have a couple other Z's with clocks that don't work, so could be handy. I installed most of the dash harness and will install the ducts soon. Oh, 'Just Dashes' covered up three of the holes that that should have been open: The dash light dimmer hole, the emergency flasher switch and the odometer reset. So, I drilled those open and installed those item. It was a bit scary drilling into a $1750 dash, but was actually fairly simple as it was just the vinyl I had to go through. I also need to look into the panel lights. I am thinking that there is a better option than the original bulbs but not sure. I will have to look into this more. Anyway, here are the pics so far Edited July 17, 20177 yr by motorman7 Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=16#findComment-525891 Share on other sites More sharing options...
July 17, 20177 yr comment_525918 As I recall, @Captain Obvious is one of the dash light LED guru's. Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=16#findComment-525918 Share on other sites More sharing options...
July 17, 20177 yr comment_525920 Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=16#findComment-525920 Share on other sites More sharing options...
July 17, 20177 yr comment_525921 Yeah, that's just not cool. Funny, but not cool! Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=16#findComment-525921 Share on other sites More sharing options...
July 17, 20177 yr comment_525940 I was looking for the speedometer dim spot that haunts my limited nighttime cruises. Everything I found and tried to view I got that upgrade image. It happened so much my anger turned to amusement. I'm sorry CO. Maybe me and some of the guys that rely on your visuals regularly could start a "go fund me"? I could save empty beer cans and get them back up in a month or two. Have you tried "my attachments" on here yet? I've got close to 90 pages so far. Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=16#findComment-525940 Share on other sites More sharing options...
July 17, 20177 yr comment_525945 Don't you think FULL beer cans would be worth more to me than empty ones???? Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=16#findComment-525945 Share on other sites More sharing options...
July 17, 20177 yr Author comment_525950 These look interesting: https://www.superbrightleds.com/vehicle/1972-nissan-240z-instrument-panel-light-bulb?make=55&model=61&scc_id=1364&year=1972 Says they work with the standard dimmer. Also, long lasting. This looks like a good option and could be cheaper than the Motorsport 4 Watt incandescents. PS: the photobucket images are not coming through. Edited July 17, 20177 yr by motorman7 Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=16#findComment-525950 Share on other sites More sharing options...
July 17, 20177 yr comment_525955 You cannot beat the prices and how long they will last. I am going to go on that site and order. Which one do you think is best? Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=16#findComment-525955 Share on other sites More sharing options...
July 17, 20177 yr comment_525957 Very nice work on the dash. If you want to stick with incandescent bulbs for the instruments, consider the Eiko A-72. It is a 4W bulb that is a perfect fit. My experience with the MSA offering several years ago was that they were not a good fit unless you were willing to give up the lens over each bulb. I really like the additional brightness from the Eiko's. Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=16#findComment-525957 Share on other sites More sharing options...
July 17, 20177 yr Author comment_525963 I am leaning towards this one. It is 25 lumens, in cool white with 90 degree beam angle. https://www.superbrightleds.com/moreinfo/instrument-panel-light-bulb/ba9s-led-bulb-4-led-ba9s-retrofit-car-classic-car-bulbs/6/ The Eiko also seems like a good option for incandescent with the 4 Watts. I am leaning toward the brighter LED with the longer life. Pricewise, it is just a bit more, but I like the fact that the LED would be longer lasting and maybe a bit brighter. Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=16#findComment-525963 Share on other sites More sharing options...
July 18, 20177 yr comment_525982 On 7/17/2017 at 6:00 PM, Captain Obvious said: Don't you think FULL beer cans would be worth more to me than empty ones???? depends on the beer. oregon just raised the price of an empty can to 10 cents Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=16#findComment-525982 Share on other sites More sharing options...
July 18, 20177 yr comment_525983 Haha! Yeah, I guess that's true. I can think of several beers that are worth less than ten cents to me. For some beers, the can would be worth more to me empty than full! Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=16#findComment-525983 Share on other sites More sharing options...
