August 22, 20177 yr comment_528623 Thanks, Rich I thought that strip between the black and orange just in front of the door hinge was weatherstripping but I believe it is just a different color of paint. Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=21#findComment-528623 Share on other sites More sharing options...
August 22, 20177 yr Author comment_528627 23 minutes ago, Patcon said: I thought that strip between the black and orange just in front of the door hinge was weatherstripping but I believe it is just a different color of paint. Yes, that is the primer that is under the paint.  I will touch that up with orange paint before I put the fenders on. Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=21#findComment-528627 Share on other sites More sharing options...
August 23, 20177 yr comment_528636 When you have you parts re plated like the door hardware do you have to take out the plastic pieces? I am also curious if the rubber grommets on the fuel line brackets will survive. A couple of them are not going to come off the line without cutting themSent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=21#findComment-528636 Share on other sites More sharing options...
August 23, 20177 yr Author comment_528654 I did not take out the plastic for the door hardware. Â The only concern there would be the part that goes through the center of the plastic. Â It seemed to plate well enough. Â Â The acids won't effect the plastic or rubber. Â It will just not plate where the rubber is in direct contact with the metal Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=21#findComment-528654 Share on other sites More sharing options...
August 30, 20177 yr Author comment_529180 Took a short break to visit my mom up in Idaho. Â That is always nice since mom always spoils me with great food. Â She is almost 79 and still cuts her own wood with a chainsaw. Â Pretty impressive. Â Â Now back to the task at hand, and the fun part, assembling the car. Â I had just a little time so I put the rear bumper on the car. Â Pics are below. Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=21#findComment-529180 Share on other sites More sharing options...
August 30, 20177 yr comment_529184 Looks better than new........and I remember what new looked like when I bought mine in 1971. Dennis Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=21#findComment-529184 Share on other sites More sharing options...
August 30, 20177 yr Author comment_529245 14 hours ago, psdenno said: Looks better than new........and I remember what new looked like when I bought mine in 1971. Dennis      You are right.  My '70 still has the original single stage paint and it never looked this good.  The '70 even has a few paint runs in the engine compartment and the overall paint has a slight ripple or 'smooth orange peelish' texture to it.  (Not sure what you really call that finish)    I was at the San Marino Motor Classic Car show a couple month ago with my orange '71 240Z and one of the judges commented that he was very impressed that I was able to produce the 'smooth orange peelish' texture of the original Z paint on my car.  Unfortunately, I had to tell him that the texture was actually the result of my mediocre painting skills and not what I was shooting for.  Smooth as glass is what I was trying to achieve. Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=21#findComment-529245 Share on other sites More sharing options...
August 31, 20177 yr Author comment_529267 Installed the passenger side quarter window.  I buffed out the frame on the polishing wheel to give it a nice shine.  You can see the difference in the first and third pics.  The polish takes out some of the very small scratches.  I remembered to paint the  inside frame area satin black before installing the window (I forgot to do this on my '71 and it looks goofy, one of those things I need to go back and fix).  I installed all new weather stripping and new 4mm screws.  It's actually a fairly easy install. Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=21#findComment-529267 Share on other sites More sharing options...
August 31, 20177 yr comment_529270 Nicely done! Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=21#findComment-529270 Share on other sites More sharing options...
September 4, 20177 yr Author comment_529578 I installed the drivers side rear window same as the passenger side.  Also polished and installed the rain gutter molding on both sides.  I  installed the hatch weather stripping.  As always, I hate putting in weatherstripping but this was one of the easier installs since the hatch was removed.  I think I will do this on all future hatch weatherstripping, it made the job so much easier.  The other thing I did differently was install the weatherstripping without glue first.  Then I went along foot by foot applying the glue to the installed weatherstripping.  Using the clamps and tape to keep things in place was also a big help.  These work well to keep everything secure and nicely aligned. Started clean-up and paint on the shock tower components.  I should be able to get those installed today once I  finish a few home items. Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=21#findComment-529578 Share on other sites More sharing options...
September 4, 20177 yr comment_529580 Looks great as usual! Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=21#findComment-529580 Share on other sites More sharing options...
September 4, 20177 yr comment_529596 Amazing work on your project, I have this topic bookmarked as a reference in case I ever get to a full resto of my car. Just wondering about the color of the hood hinge torsion bars? I thought they were black as they can be seen though the grill. Link to comment https://www.classiczcars.com/forums/topic/56833-deja-vu-1971-restoration/?&page=21#findComment-529596 Share on other sites More sharing options...
