January 28, 20178 yr Author comment_511251 3 hours ago, jfa.series1 said: These might help - mind you my car is 12/70 so there are likely some changes by the time we get to your build date. The OE flasher on my car mounted to the steering column above the pedals. I have since replaced it with an electronic flasher, it does not have the tab for a mounting screw. I've also replaced the 4-way flasher with the same electronic unit - its tucked up into the wiring bundle on the second pic immediately below the tape wrapped harness. awesome, thanks so much!! Link to comment https://www.classiczcars.com/forums/topic/56884-wires-dangling-and-minor-electrical-issues/?&page=3#findComment-511251 Share on other sites More sharing options...
