Posted January 20, 20178 yr comment_510734 I am going to refresh the Rats Nest EFI system on my 77 280Z. I have a spare intake and would like to shave the EGR and then have it powder coated. I'm interested in how others have done this. Also, debating on which fuel rail to get to replace my old 3 piece unit, either a 78 (or newer) single piece rail or get Palnet to make one up for me. Appreciate any thoughts on pros/cons. Link to comment https://www.classiczcars.com/forums/topic/56911-shaving-egr-from-the-intake/ Share on other sites More sharing options...
January 21, 20178 yr comment_510746 There's an N42 on the classifieds now. I put a block off plate on my n47. There's a tunnel under there I don't think you can shave away. People talk about shaving, they're talking about the bosses all the crap bolts into. If you have access to a drill press and taps you can make your own rail for less than $50. It isn't easy though so Palnet is the easiest if you have the money. Link to comment https://www.classiczcars.com/forums/topic/56911-shaving-egr-from-the-intake/#findComment-510746 Share on other sites More sharing options...
January 21, 20178 yr comment_510747 You can read my thread for my process. A TIG welder is needed to weld the holes up. I would also preheat the part to allow offgassing for a better weld. Any cast part welds poorly but you can still get a decent result. Especially if you are planning on powder coating. Link to comment https://www.classiczcars.com/forums/topic/56911-shaving-egr-from-the-intake/#findComment-510747 Share on other sites More sharing options...
January 21, 20178 yr comment_510748 Go pallnet for the rail. Get the 11mm oring style and buy stock Cressida injectors (198cc) for similar stock performance but will allow you to swap them out easily later if you upgrade the ecu. Clean, upgradable and affordable. Link to comment https://www.classiczcars.com/forums/topic/56911-shaving-egr-from-the-intake/#findComment-510748 Share on other sites More sharing options...
