New Fujitsubo Exhaust System to be Released
240260280
2 hours ago, riceburner said:
I run 3" mandrel bent all the way to the rear then split it into twin 60mm at the Reinhard muffler.
It must get fairly warm, the tips changed colour after the first track day.
Not sure what the flow rates are when comparing 3" with twin 60mm.
That's cute - what does a Reinhard muffler cost these days ? How long is it overall and also just the 'box' please ?
Pls give me the model number and/or link. That is ideal. Not obvious from their website (do you have to order from Japan...?)
10 hours ago, Sean Dezart said:
I had a set of S50B32 headers here to compare (you know why Franky) :
38mm primary pipes (makes me laugh when people say they 'must' have 44s, 48s, 50s for their Z!) and twin 50mm secondaries.
Diameter
lenghth
so many variables.  the sb50b32 is a good setup though.  for that application.
11 hours ago, Sean Dezart said:
Hi Sean, these are the dimensions measured roughly, excuse the diagram. Might be suitable as a big bore option for your line of exhausts.
Reinhard stopped selling them separately after I got this in 2013. A few Aus guys tried buying them but they would only sell the entire system.
2x JDM exhaust photos and note the drawing (thanks Alan T) - especially the longer resonator !
My 'JDM' muffler of which the 'box' is 380mm long with a 100mm long entry pipe.
Exit pipes are 180mm long (top) and 150mm (lower) at maximum lengths (on the top of each tube).
What are these two, Sean? The one on the left is aftermarket. Looks like a stainless Spirit Garage item to me. The one on the right looks like one of the old MSA systems.
Edited by HS30-H
