April 18, 20187 yr comment_547620 By the way, I believe it was John Coffey who said he had never fitted an aftermarket exhaust including a header that did not need some tweaking. I agree and while the Stahl header did a good job around clearing the steering shaft the flange not being equal thickness to the intake was a real pain and made it very hard to seal. I had to have a machine shop make up stepped washers, same as others have experienced.  Link to comment https://www.classiczcars.com/forums/topic/56953-new-fujitsubo-exhaust-system-to-be-released/?&page=27#findComment-547620 Share on other sites More sharing options...
April 18, 20186 yr comment_547628 Was it the new or old version? What size diff did they have? What car was it being fitted to? Link to comment https://www.classiczcars.com/forums/topic/56953-new-fujitsubo-exhaust-system-to-be-released/?&page=27#findComment-547628 Share on other sites More sharing options...
April 18, 20186 yr comment_547630 I just bought the new version. Should be here in a week or so. I will be able to give details on its fit. Link to comment https://www.classiczcars.com/forums/topic/56953-new-fujitsubo-exhaust-system-to-be-released/?&page=27#findComment-547630 Share on other sites More sharing options...
April 18, 20186 yr comment_547633 7 hours ago, ollie said: Here's the Spirit Garage one and there is lots of room to still tuck it up even higher in the transmission tunnel. That's an R200 it is rounding too. what size primaries did you go for? Link to comment https://www.classiczcars.com/forums/topic/56953-new-fujitsubo-exhaust-system-to-be-released/?&page=27#findComment-547633 Share on other sites More sharing options...
April 18, 20186 yr comment_547637 42mm Link to comment https://www.classiczcars.com/forums/topic/56953-new-fujitsubo-exhaust-system-to-be-released/?&page=27#findComment-547637 Share on other sites More sharing options...
April 18, 20186 yr comment_547642 Only thing I don't like about the new fujitsubo is the exhaust hanger not being welded onto the muffler. I wonder why they did that? Link to comment https://www.classiczcars.com/forums/topic/56953-new-fujitsubo-exhaust-system-to-be-released/?&page=27#findComment-547642 Share on other sites More sharing options...
April 18, 20186 yr comment_547647 I think they did a "field fit" option to accommodate a variety of cars. The muffler hanger closest to the diff on the SG one is about 2" too far but I doubled the hangers and its no big deal. But ya, finding folks comfortable and competent welding stainless, in our town at least, isn't easy. Link to comment https://www.classiczcars.com/forums/topic/56953-new-fujitsubo-exhaust-system-to-be-released/?&page=27#findComment-547647 Share on other sites More sharing options...
April 18, 20186 yr comment_547648 I can tig weld stainless. But I would rather not weld on a brand new 900$ exhaust. Link to comment https://www.classiczcars.com/forums/topic/56953-new-fujitsubo-exhaust-system-to-be-released/?&page=27#findComment-547648 Share on other sites More sharing options...
April 18, 20186 yr comment_547655 Cool, you're way further down the road than I was...if if helps any I can take a pic of how the hangers are welded onto mine for location and type. Link to comment https://www.classiczcars.com/forums/topic/56953-new-fujitsubo-exhaust-system-to-be-released/?&page=27#findComment-547655 Share on other sites More sharing options...
April 18, 20186 yr comment_547666 Was it the new or old version? What size diff did they have? What car was it being fitted to?They were trying to fit the old style Fujitsubo exhaust..... With "H" style resonator .... to a left hand drive 240z.Not sure what differential? In this case the differential didn't seem to be the cause of poor fitment like it was for me running a R200 differential. Thus Supporting my original post at the beginning of this thread that While it's a well crafted and quality made exhaust system with beautiful welds the fitment needs improvement. Hopefully one of the reasons for the new version.Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/56953-new-fujitsubo-exhaust-system-to-be-released/?&page=27#findComment-547666 Share on other sites More sharing options...
April 19, 20186 yr comment_547683 7 hours ago, Dreamzz said:  They were trying to fit the old style Fujitsubo exhaust..... With "H" style resonator .... to a left hand drive 240z. Not sure what differential? In this case the differential didn't seem to be the cause of poor fitment like it was for me running a R200 differential. Thus Supporting my original post at the beginning of this thread that While it's a well crafted and quality made exhaust system with beautiful welds the fitment needs improvement. Hopefully one of the reasons for the new version. Sent from my iPhone using Classic Zcar Club mobile  So quite simply they were fitting an exhaust that is documented my fujitsubo not to fit. just shows their actual level of understanding about what they fit to cars.  It’s not for big diffs. Link to comment https://www.classiczcars.com/forums/topic/56953-new-fujitsubo-exhaust-system-to-be-released/?&page=27#findComment-547683 Share on other sites More sharing options...
April 20, 20186 yr comment_547730 Buttoning up the SG system is still causing some pain...the stock crankcase breather hose to PCV on the balance tube, zero chance that will reach without being very close / touching one of the primaries so I am assuming that hose will simply melt upon start up. Has anyone ever sourced a different hose length that has those offset sizes for the crank to balance tube?  Secondly I don't see any way to use the stock airbox as the edge sits on the header primary as well when it is moved into place. I'm going to go take another look but if I go with the K&N filters for the SU's then that opens up needing to provision for the valve cover breather...or at least put a K&N filter on that too. I wanted to keep the PCV system in tact if possible. Cheers. Link to comment https://www.classiczcars.com/forums/topic/56953-new-fujitsubo-exhaust-system-to-be-released/?&page=27#findComment-547730 Share on other sites More sharing options...
