4 minutes ago, Yarb said:
Not sure what you’re asking here. You are talking about exhaust correct?
If the header will work with the stock 280z intake manifold.
15 hours ago, Yarb said:
Are you buying a new system or trying to figure out if a used system will fit the car? Need more information
I'm trying to figure out if this system will fit my Z. Its a 76' with the stock intake manifold. Everything I've read - from the supply side - states that these are for triple carb setups and am wondering if anyone has tried doing it on the EFI cars.
I have this system on my 240z with SUs. The header simply bolts onto the head (obviously) and I had the header ceramic coated to keep the heat down. I know nothing about the efi systems on a 280, but if it is all on the intake side like a carb then you could have heat issues or more likely fitment issues. The header mounts cleanly on my head, I bet it would on your 280 but without knowing first, it could be a very costly error. And I'm the king of costly exhaust mistakes...
Edited by ollie
Are you buying these from a supplier? If so it should state the fitment parameters. Gotta know more details. Is this exhaust new or used?
