Wheee! Was that in a running car or a barn find?
It was sitting for about 15 years like that. And then I started it and it ran normal... ON THAT GAS!!! I thought the tank was empty because the gauge was on empty. Of course it was corroded solid. The tank was 7/8th full of that cappuccino cocktail.
The fuel story is incredible - I didn't know varnish was that flammable!  Although it may be a testament to the reliability (?) of the Z and SU's.
My clutch reservoir had a thick black film over the bottom half.
I was thinking the same thing. I can't believe it actually ran on that stuff!!
I ran my 260 for a little bit on the old stuff from the tank and it left this very sticky residue all over the insides of the carbs and intake manifolds. After five minutes of running, the throttle butterflies got sticky and would hang up just from the glue. Gross.
7 hours ago, wheee! said:
Found this...
Wait... Is that your car running on that nut-brown gas???
Must have been quite the surprise when you drained the tank to find it looked like that!
