Rij Martin Posted February 4, 2017 Share #1 Posted February 4, 2017 My question is can you swap a 280zx clock (or any of the trio gauges) into a 280z? I have done a bit of searching and can't find a write up where someone has put the ZX gauges into the s30. Do they use the same connectors? Link to comment Share on other sites More sharing options...
Martzedcars Posted February 4, 2017 Share #2 Posted February 4, 2017 The 3 gauges in a 280zx are 1 set, 1 housing.. and have different wiring / connectors Link to comment Share on other sites More sharing options...
JSM Posted February 20, 2017 Share #3 Posted February 20, 2017 On 2/4/2017 at 7:26 AM, idgemartin said: My question is can you swap a 280zx clock (or any of the trio gauges) into a 280z? I have done a bit of searching and can't find a write up where someone has put the ZX gauges into the s30. Do they use the same connectors? Expand This is a 79 ZX clock. Notice how the face isn't completely round. I just pulled this today as I was curious on your post and curious myself. You might be able to figure something out but it won't be easy. The other thing is the plastic face screws right to the front of the 3 pod bezel making adjust the hands an issue. And of course it doesn't sit square either. Two wire hookup is a breeze and still tells time pretty good! Link to comment Share on other sites More sharing options...
EuroDat Posted February 21, 2017 Share #4 Posted February 21, 2017 Why do you want the change clocks. If you are doing it because you happen to have a ZX clock handy, it might be easier to try and repair the original. Do you still have the original? Here is a write-up by @monkeyman in australia. It seems an easy procedure to follow and would probably be a lot easier than converting a ZX. I think zclocks does an exchange service. How to fix your 260Z or 280Z clock - rev 1.pdf Link to comment Share on other sites More sharing options...
