Engine rough running - at wits end
the_tool_man
  On 2/5/2017 at 10:05 PM, the_tool_man said:
The short version. Replaced fuel filter and lines, fuel pressure regulator, injectors, AFM, coil, plugs, plug wires and coolant temp sensor. Cleaned and verified coolant temp circuit function at ECU. Air gap between reluctor and pickup set to 0.012. Timing set to 10 degrees BTDC. All of this was done in response to various symptoms, such as low fuel pressure, misfire, etc. over the past year of off-and-on repairs interrupted by health problems.
Now it will idle roughly when cold. If I rev the engine it backfires and then revs okay. But it still runs roughly. Once the engine starts to warm up, it won't stay idling more than 15 seconds or so before sputtering to a stop. New plugs don't read yet. Old ones were sooty, even when fuel pressure was low.
Expand
  On 2/27/2017 at 3:06 PM, the_tool_man said:
My methodology at this point is to take the list of possible causes provided by the contributors to this thread, and eliminate them, starting with easiest first.
Vacuum leaks seem to be most likely, and with the exception of an intake manifold gasket leak, would seem to be easiest to check.  Then I'll test the CSV.  Next is a compression test.  Then valve lash, timing chain, etc.
I didn't mention it because it didn't seem important.  But the EGR valve is really dirty.  The pintle moves freely under finger pressure.
Expand
I would do everything listed in the Engine Tuneup chapter, in order.  The first action is valve lash adjustment, because it's really important.  But most of use do it last because it's oily and smelly and looks complicated.  I'm pretty sure also that there's a test for EGR function in the Emissions chapter.  Once you've passed by the easy fix zone, the changes made usually add up to "out of adjustment".  You have to determine that the basics are correct.  You can't really be effective doing easy first.
Good luck.  Use a small hammer to loosen the locknuts on the rocker arm pivots, if they need adjustment.  At least open it up and examine, and take measurements if you have the feeler gauges.  You can also check the timing chain and cam timing while you're in there.  Engine Mechanical chapter.  If you don't have time we can supply some pictures.  But you have to get on the methodical track.
I picked up a gasket and made a block off plate for the EGR. I used a borrowed stud remover to try getting the studs out. But they wouldn't budge. Rather than break them off, I decided to just use the old EGR spacer on top of the block off plate.
No change in running, vacuum reading, etc.
I found the PCV hose under the intake. But I'll need double jointed elbows to get to the thing. I'll go at it from below on my next foray. But I ran out of time tonight.
Sent from my XT1254 using Classic Zcar Club mobile
Looks like a nice attempt at finding the leak, bad that it wasn't.
There's a thing we know as the "yogurt cup test" from a very smart member with good common sense.  You shove a cup into the accordian hose between the AFM and the throttle body.  Pull the brake hose off and blow as hard as you can.  I put my valve cover gasket on upside down, straight side to the passengers side: wrong, and when I blew into the hose my hair moved. LOL
You might try that and listen for the air.
Don't install the plate until you examine the inside of the EGR passages.  The problem that they have is that the metal between the two ports rots out.  So your plate might not do anything.  Stick your finger down there and make sure the metal is solid.  The EGR valve is controlling flow from the round hole to the square hole, gasket-shape-wise.  If the metal is solid, then focus on sealing the square hole.  The round hole won't matter if you've sealed off the tube from the exhaust manifold.
Expand
Hair only moves if you're a blowhard?
Funny, but that test would probably work on the EGR system too, to see if the passages and valve are okay.
Out of interest, did you try the double nut technique to remove the studs?  That is what worked for me when I did a lot of manifold work 3 or 4 years ago.  I did have the advantage of the manifold off the car though.   Wanted to replace the studs with ss bolts for a cleaner look with the block off plate.
Best of luck on your low vacuum issue.  Will be interesting to know what the ignition timing is currently at,  when you get to that
Thank you!  I'll save that. :)
Zed Head I hooked a newer modem/router combo the renters left in my house.  Now getting a previous attachment, I have 46 pages, as soon as I click the whole page is downloaded.  It's amazing how much faster the downloads are.  Surf Board 6700.
Sorry to waste a post in your thread Tool Man.  I'll try to offer some help, ideas.
I did the yogurt cup test months ago. It would build pressure as it should. But it would probably be a good idea to repeat it.
I checked the web between the intake and exhaust ports for the EGR.  It's solid.  I was careful to clean the surface of the intake manifold so the new gasket wouldn't leak.  I did not plug the pipe from the exhaust.  So I wanted to make sure neither side would leak.
I tried double nutting the studs. But this required using an open end wrench to loosen them, which put a lot of bending on them. The extractor I borrowed uses cam driven rollers to grip the stud all around. I put a big ratchet handle on it and pulled pretty hard to the point where I think I yielded the studs a bit. In another thread I detailed my ordeal with snapped fuel injector screws. Rather than break these, I used the EGR spacer to let me put nuts on the existing studs. At some point I'll use heat to get them loose. But I'm moving on for now.
Timing is 10 deg. BTDC at idle. Vacuum advance seems to be working. But working alone I can't reliably correlate rpm and timing.
Edited by the_tool_man
I got one end of the PCV hose loose, so I could give it a good inspection. No apparent issues.
I've come up with a plan to use smoke to look for vacuum leaks. But I couldn't do that until a friend brings me his fog machine. So tonight I did a compression test. After warm-up:
1:152psi
2:152psi
3:158psi
4:155psi
5:155psi
6:150psi
An 8psi range (5℅) seems pretty good. Here's a pic of the plugs (in order 1-6 left to right):
They probably have about fifteen minutes of total run time on them.
No time for more than that. So I put everything back together and checked the firing order for the fourth time.
Of course there's always something that goes wrong. I have no fuel pressure now. Not sure how since I didn't touch the fuel pump circuit.
  • Who's Online   0 Members, 0 Anonymous, 470 Guests (See full list)
