February 10, 20178 yr comment_512373 Thanks to you Kats!! You Sir, are the best! You have filled in all the missing information with your perfect documentation. Thank you, thank you, thank you! Jim D. "Zup" Â Link to comment https://www.classiczcars.com/forums/topic/57001-series-1-hatch-vent-duct-clips-restoration-info-needed/?&page=4#findComment-512373 Share on other sites More sharing options...
February 10, 20178 yr Author comment_512374 MIND BLOWN!!! Â Thank you Kats for adding the detail to the pictures. Â The nut spring 08961-43210 looks like a fairly common piece. Â In fact, I think I have some that came with a body hardware kit for something. Â I will have to look tomorrow after work. I should hopefully have the quote for the clips from the fab shop tomorrow. Â I will keep everyone posted. Edited February 10, 20178 yr by Hardway Link to comment https://www.classiczcars.com/forums/topic/57001-series-1-hatch-vent-duct-clips-restoration-info-needed/?&page=4#findComment-512374 Share on other sites More sharing options...
February 10, 20178 yr comment_512378 Thank you Jim and Hardway, I was drawing this a while ago , but now no need , everyone's conversations drew the answer . Kats Link to comment https://www.classiczcars.com/forums/topic/57001-series-1-hatch-vent-duct-clips-restoration-info-needed/?&page=4#findComment-512378 Share on other sites More sharing options...
February 10, 20178 yr Author comment_512404 Okay, I got the quote back from the shop and the breakdown is below.  These are spring steel, not stainless steel. Qty. 100 without plating (bare spring steel) $6.92/ea.  With clear zinc plating, $7.93/ea. Qty. 200 without plating (bare spring steel) $5.97/ea.  With clear zinc plating, $6.47/ea. As you can see, there is a price cut for going with 200.  I would have to of course pay for the full run upfront or once complete, I would need one clip from someone for them to prototype off of, and it would be a 5 week turn around once everything is signed.  Shipping would be $5/set to anywhere in the cont. US including the small padded envelope and I would add $5/set for my time.  Since each car needs 4 clips the math would work out to the following. Plated: $41.72/set  Not Plated: $37.68/set  This is based on a qty. of 100 as I do not want to be sitting on a mass inventory of clips that may never sell. I show this because I want to be 100% transparent and show everyone what it really costs to get this kind of work done.  So the question is, are the prices beyond what people would pay?  Would you prefer plated or bare steel?  Who would send me a clip to borrow?  I would give you a discount on a set of clips of which we can talk about. Edited February 10, 20178 yr by Hardway Link to comment https://www.classiczcars.com/forums/topic/57001-series-1-hatch-vent-duct-clips-restoration-info-needed/?&page=4#findComment-512404 Share on other sites More sharing options...
February 10, 20178 yr comment_512409 The extra for plating is worth it. I'll go for two sets. My Z is in storage 130km away so I can not send clip samples. It would be good to have the manufacturer test the first few for correct fit before they whip off 200. Link to comment https://www.classiczcars.com/forums/topic/57001-series-1-hatch-vent-duct-clips-restoration-info-needed/?&page=4#findComment-512409 Share on other sites More sharing options...
February 10, 20178 yr comment_512418 I will gladly provide the sample if it will be returned un-damaged. You could have it in hand on Monday if this proceeds well. I'm in for a set of cad plated. If it is required for the "test fit", I could send the entire NOS ductwork assembly I have as the "mule" provided as above. Link to comment https://www.classiczcars.com/forums/topic/57001-series-1-hatch-vent-duct-clips-restoration-info-needed/?&page=4#findComment-512418 Share on other sites More sharing options...
February 10, 20178 yr comment_512421 I"m in for a set of the plated type as well. Link to comment https://www.classiczcars.com/forums/topic/57001-series-1-hatch-vent-duct-clips-restoration-info-needed/?&page=4#findComment-512421 Share on other sites More sharing options...
February 10, 20178 yr Author comment_512423 Thank you Zup.  I think they just need the clip to take exact measurements.  I would make sure you would get it back in original condition.  We can draw up an agreement around it if you like.  I will PM you all of my contact information.  I think I am going to do the run of 100 first with the clear zinc as the corrosion protection seems worth it, that would create 25 sets and I believe all of those would sell. 50 sets is a tough sell unless everyone believes the demand is there. Edited February 10, 20178 yr by Hardway Link to comment https://www.classiczcars.com/forums/topic/57001-series-1-hatch-vent-duct-clips-restoration-info-needed/?&page=4#findComment-512423 Share on other sites More sharing options...
February 10, 20178 yr comment_512425 Put me down for a set of plated. Don Pappe Seattle Link to comment https://www.classiczcars.com/forums/topic/57001-series-1-hatch-vent-duct-clips-restoration-info-needed/?&page=4#findComment-512425 Share on other sites More sharing options...
February 10, 20178 yr Author comment_512431 I had some time to dig around in the garage and found some spring nuts as Nissan calls them. Â I believe this kind of hardware is very common, we just need to know the dimensions of the OEM pieces. Â Once this is known, a suitable replacement can surely be located. Â No need to have these fab'd up. Â Below are some pictures of what I found in my stash. Â I probably have more in other places but this should help. Â US nickel for reference. Link to comment https://www.classiczcars.com/forums/topic/57001-series-1-hatch-vent-duct-clips-restoration-info-needed/?&page=4#findComment-512431 Share on other sites More sharing options...
February 10, 20178 yr comment_512435 How it's made. I think measuring tape could be stock. Â Â Link to comment https://www.classiczcars.com/forums/topic/57001-series-1-hatch-vent-duct-clips-restoration-info-needed/?&page=4#findComment-512435 Share on other sites More sharing options...
February 16, 20178 yr Author comment_513027 A big thank you to Zup for supplying the OEM clip and spring nut.  I have dropped it off and signed the paper work for production work.  Once they create 1 I will go inspect it to give the green light on moving forward with the other 99.  I am doing a run of 100, clear zinc plated, made of spring steel.  It will be 4-5 weeks until I see the first one to inspect.  I am hoping to make it to Fastenal and Grainger tomorrow or Friday to see if a spring nut is available that closely matches the OEM that Zup sent me.  Once the full run of clips are done I will post up all the details in the Garage Business forum. Link to comment https://www.classiczcars.com/forums/topic/57001-series-1-hatch-vent-duct-clips-restoration-info-needed/?&page=4#findComment-513027 Share on other sites More sharing options...
