Help!!! I want to go from an auto to manual...
texasz
How hard is this conversion? The car is a '73 240Z with an auto tranny and I want to put in an early manual 5-speed. I know that the tranny swap is not too bad but how about the clutch pedel and linkages for it???
I must get this answered quickly so any help would be great!!
Well, it is not too hard to do actually, just a pain in the arse.
PARTS LIST:
Transmission
Manual starter
Clutch kit (I suggest a Centerforce) MSA sells them
Pedals - both the brake and clutch (I have a set)
Flywheel with bolts (I have that too)
Clutch Master Cylinder (bolts right in)
Slave cylinder
rubber line to slave cylinder
medal hydraulic line
pilot bushing for the crankshaft (autos did not get one)
I do not know if the driveshaft is interchangeable???
Also the rubber boot for the shifter and actually the center console is different, but I just made me a custom outer shifter boot. Works great and is a BUNCH cheaper than a new console.
That is most of it from the top of my head. Let me know if you need any more help. Also I am in San Antonio (not too far from you) if you need visual help.
Hi
I did this conversion about 2 years ago. The only real pain is switching from gas/brake pedal to gas/brake/clutch. You have to change the 'bracket' that they attach to as the one for automatic trannies won't work. It's a pretty tight fit, especially working upside down, if you don't take the dash out first.
But other than that it's a pretty easy swap. The holes for the clutch master cylinder are already cut into the firewall (they have a cover over them) and the tranny will bolt right up.
Of course you will have to install the hydralic line from the master cylinder to the slave cylinder, but again, the rubber supports are already there (holding the brake line).
Good luck. If you run into any problems just write.
Peter
  • 1 month later...
The deal on this car fell through. The seller did not have the title nor had he ever. The owner before him MAY have been the titled owner, but I do not know. After looking into this I decided that what was best for me was to have the current owner obtain the title. However, he must not want to get rid of the car that badly as he pretty much said that he had no time to do this and would just donate the car to charity. The joke is on him though, to my knowledge nobody will take a car without a title. ROFL
So I'm sorry that I will not have any parts to pass on. But you may ask this guy, I bought the engine about a month ago and while I was there they pulled the auto tranny off it as I did not want it and had no need for it. He may still have the tranny and sell you the parts. I know that he was in need of the money do continue his V8 conversion.
  • 2 months later...
  • 1 month later...
  • 1 year later...
  • 8 years later...
I'm sorry for kicking this topic, but I have a problem with my swap..
everything from the swap went fine, but I can't get the bushing in the crankshaft. it seems to be that the crankshaft is already the right size to fit the main transmission shaft without a problem.
the bushing that I have is about 2-3mm to thick everywhere!
could it be that I have another crankshaft? cause the inner diameter is exactly the same as the outer diameter of the transmission shaft, and it fits without any slop!
  • Who's Online   2 Members, 1 Anonymous, 650 Guests (See full list)
