Cold or Hot valve adjustment with Schneider 274F Cam
jalexquijano
Im having an issue with cylinder #4 as whenever i race the car and make a couple of stops and leaving the car at idle for 5 mins in the garaje, spark plug 4 (NGK BP5ES) comes out fouled and sooty. I have both front and rear roundtop su carbs at 3 turns clockwise. All of the other plugs are burning correctly. Could my car be running only on 5 cylinders? mechanic says i need a valve adjustment but cold and not hot. Do you concur???? the car does not have the original cam but a Schneider 274F to compensate as my engine was bore to 2.6 L and not 2400 cc as original.
http://schneidercams.com/274FL6.aspx
Is a valve adjustment at cold required better than Hot?
Hard to do a consistent "hot" valve adjustment since by the time you get to the last one it's a whole lot cooler than the 1st one you did. The valve train wouldn't change temp during a "cold" adjustment unless you got really warm hands.
