Wierd whining sound coming from the engine compartment...
v12horse
There is this wierd sound that is coming from the engine compartment. It seems to be there when I start it, but when it starts moving it is still there but not as much. It sounds like an aweful whine. The car just started making the sound today. The only thing that I did different was not warm it up because I was in a rush, but I don't think that would be it. I thought it was coming from the fan or the fan shroud, but I am not certain. It is an early 260z. If any one can help or give ideas that would be great. Thanks.
-Ben
It would really help us if you could pin point where the sound is coming from. It might be a bearing but unless you can pin point it who knows which one. Take a long screw driver phillips or flat tip it doesn't matter the longer the better.
Place the tip of the screw driver against a stable piece of metal close to a bearing while the engine is running (watch out for that fan!) put it as close to the bearing as you can.
Check the alternator, water pump, air pump & A/C.
Next put your ear against the handle of the screw driver and listen. Move the screw driver around to different parts and listen. Basically you are using the screw driver like a stethascope.
Eventually you will find where the whine is coming from.
I have not heard that sound anymore since I wanted to go in there and check what it was. Figures.. I am going to be driving it from the Bay Area to Orange county next week for the Motorsport Z nationals so that will be the test of what that sound was. I want to find that kitty. Darn. Thanks a lot.
-Ben
