The first picture (one on top) is choke cables and the second is the choke lever which is mounted on the center console and gets attached to the "loop" part of the choke cable.
Picture 5 is a clamp which holds the brake booster vacuum line in place and attaches to the firewall.  Picture 6 is also a clamp and holds the brake booster valve and is also attaches to the firewall.
Not sure on the others.
Hope that helps.
Mike.
choke cable
choke lever
transmission crossmember bolts
carb throttle rod mount - bolts onto firewall
something to hold a hose
ignition resistor by the coil
brake booster check valve bracket - mounts to firewall
pads that go under cowl at either end
Chuck
Edited by cbuczesk
You'd be better off using the choke lever mounts that Art Singer sales on ebay, $30-$40?
They screw down on the transmission tunnel in front of the ashtray hole not the plastic console like the OE one in your 2nd picture.  That's one of the best aftermarket Z parts out there in my opinion.
