November 26, 20195 yr comment_588304 Can you confirm the precise diameter for this hose is 5/16"? Link to comment https://www.classiczcars.com/forums/topic/57121-size-fuel-line-replacement/?&page=3#findComment-588304 Share on other sites More sharing options...
November 26, 20195 yr comment_588305 As I said earlier in this thread... "If this is the return line from the fuel rail I used 3/16 as I stated in the prior post. The supply side (where the stock fuel filter is) is 5/16" It's 5/16 supply and 3/16 return back at the tank also. Link to comment https://www.classiczcars.com/forums/topic/57121-size-fuel-line-replacement/?&page=3#findComment-588305 Share on other sites More sharing options...
November 26, 20195 yr comment_588308 1 hour ago, jalexquijano said: Can you confirm the precise diameter for this hose is 5/16"? I refer specifically to this one that is breaking and is installed to the input of the airtex 8012s elecric fuel pump before the filter as shown. Asides from this i will need a list of each and every fuel hose for the complete 1972 240z. I am travelling to miami and would like to source locally. Link to comment https://www.classiczcars.com/forums/topic/57121-size-fuel-line-replacement/?&page=3#findComment-588308 Share on other sites More sharing options...
November 26, 20195 yr comment_588312 2 hours ago, jalexquijano said: I refer specifically to this one that is breaking and is installed to the input of the airtex 8012s elecric fuel pump before the filter as shown. Asides from this i will need a list of each and every fuel hose for the complete 1972 240z. I am travelling to miami and would like to source locally.  No need to go any farther than your local auto parts store. Measure each flexible hose you want to replace. Add the lengths and round up to the next foot. Cut the new hose to fit and replace any suspect clamps with new ones. Link to comment https://www.classiczcars.com/forums/topic/57121-size-fuel-line-replacement/?&page=3#findComment-588312 Share on other sites More sharing options...
November 27, 20195 yr comment_588327 I need the full list of hoses. I could only manage to take pictures of some of them. Edited November 27, 20195 yr by jalexquijano Link to comment https://www.classiczcars.com/forums/topic/57121-size-fuel-line-replacement/?&page=3#findComment-588327 Share on other sites More sharing options...
November 29, 20195 yr comment_588399 Nobody cares each length. You buy 10 foot for less then 10$ take one hose out cut the length put it in and done. Link to comment https://www.classiczcars.com/forums/topic/57121-size-fuel-line-replacement/?&page=3#findComment-588399 Share on other sites More sharing options...
17 hours ago17 hr comment_675935 On 3/8/2018 at 2:09 PM, w3wilkes said:I used 5/16 on the line from the tank to the fuel rail. 3/16 on the return line from the fuel rail to the tank. What's the possibility that you have the lines on the fuel rail reversed?Seems like if these were inadvertently reversed it would cause all kinds of engine run problems.What kind of problems? Link to comment https://www.classiczcars.com/forums/topic/57121-size-fuel-line-replacement/?&page=3#findComment-675935 Share on other sites More sharing options...
5 hours ago5 hr comment_675943 11 hours ago, 72 Datsun 240z said:What kind of problems?A possibility of fuel starvation. The end of the return of the fuel rail is restricted so there is some back pressure on the supply side to the carbs. If the lines were reversed that back pressure won't be there to feed the carbs. Link to comment https://www.classiczcars.com/forums/topic/57121-size-fuel-line-replacement/?&page=3#findComment-675943 Share on other sites More sharing options...
